Garmin Forerunner 3...
[Closed] Garmin Forerunner 305 gone wrong - repalce or repair?
 aw
My Garmin Forerunner (wrist watch type GPS) which I have had about 4 years has gone wrong. I think it is the battery as will not charge from PC or mains. It has done sterling service and I have loads of data from it.
Can I repair it? Is this a common fault?
Should I replace it with another forerunner or is there something better around nowadays?
I used to use the HRM element as well but not the cadence part.
Posted : 22/01/2011 12:43 am
It's not the contacts between charger and watch unit is it seem to rememer this can e an issue?
Posted : 22/01/2011 12:52 am
 aw
I dont think s wellhung because I am using two methods to charge; through the USB on the PC and through a mains adapter. I will check however to make sure.
Posted : 22/01/2011 12:56 am
 aw
I was wondering if I have to replace it whether its best to stick to the forerunner or is there something better around these days?
I am on garmin connect and so pretty much set up for Garmins
Posted : 22/01/2011 1:05 pm
My 305 lasted about 4 years also, eventualy succumbed to water ingress. I took it apart and all the internal contacts were green and corroded. Same symptoms as yours.
Replaced it with the 310XT which is fantastic if a bit pricey. Its clains to be fully waterproof rather than the shower proof 305. Doing London Triathalon this year so it seemed a sensible buy.
That said, if you don't get it wet, the 305 on Amazon is a steal
Posted : 22/01/2011 1:31 pm
aw - this is a well reported problem with early 305s. there is a contact failure inside the body of the watch. Garmin are pretty good about providing a reconditioned replacement for about £60 I think.
Unfortunately its not a warranty thing though. Although Id disagree. Mrs S had one replaced like this and it's been fine since. Give Garmin UK a call to find out more.
You will also find lots of similar experiences on the running sites
Mrs S still loves hers, and does many miles a week with it. It's been indispensable for her training as well.
Posted : 22/01/2011 1:33 pm
Give garmin a call
they have a standard repair cost and if it can't be economically repaired they replace with a reconditioned unit (and 12 month warranty) for that price.
Posted : 22/01/2011 1:41 pm
Second the ring Garmin approach, had my edge replaced twice (second time free) due to contact problems. Very fast and good service.
Posted : 22/01/2011 2:21 pm
 aw
Thanks guys...looks like I am giving Garmin a call!
I do like the 305 and cannot afford anything more expensive really.
Posted : 23/01/2011 7:44 pm
