Hello,
I have a Garmin FIT file where the elevation has messed up due to bad weather and water getting into the barometric pressure hole son the underside.
I have tried the elevation correction tool in Garmin Connect but that doesn't fix it. Does anyone know of another solution / tool / website that might be able to sort it out? I have had a google already and nothing jumps out.
Thanks in advance!
Posted : 07/04/2015 9:05 pm
Garmin Connect "knows" that you have a barometric device and disables elevation correction (barometric is generally better). I don't know if you can select the option manually (I don't use Connect)
[url= http://www.dcrainmaker.com/2010/05/understanding-sport-device-gps.html ]This article might help[/url]
Posted : 08/04/2015 6:26 am
