Garmin file problem...
[Closed] Garmin file problems
4 Users
I am trying to down load a route from pedal up north, I can see the file I want to down load in a gpx format which is what I need to transfer to the garmin, yet when I save it, it saves it as a text file, can any one help
Posted : 26/02/2017 9:22 am
The file is a txt file that you can read. Is it just that it doesn't have a .gpx file extension? If so then just rename it on your puter
Posted : 26/02/2017 9:25 am
Which route is it? I'll try it myself
Posted : 26/02/2017 9:27 am
its the high st route on pedal north, I seem to rember having this problem be fore and it was a web browser problem but cant recall how I fixed it
Posted : 26/02/2017 9:33 am
High_St_tx.gpx
that's what the link looks like on my pc, yet when I try and drag and drop in to the new files section on the garmin it wont work, I can download of other sites just not this one
Posted : 26/02/2017 9:37 am
Try renaming it? I seem to remember that fixing an issue I had it the past.
You can also test the .gpx file isn't corrupted by viewing it on a gps viewing website like
http://www.gpsvisualizer.com
Posted : 26/02/2017 9:43 am
Ok I sorted it out, just in case any one else has the same issues, it is a web browser problem, I used fire fox and it work fine sort of ish
Posted : 26/02/2017 10:02 am
