I'm looking to do a trip to Scotland which needs more than one custom map each containing more than 100 tiles, but I can't get more than one map on the Garmin without getting the 'Too many custom map images. They will not all be displayed' message.
For normal rides I just swap the single custom map I need onto the internal hard drive and off we go, but I have a memory card and was looking to save 3 or 4 custom maps on there and just enable each map for the area we drive to, but the Garmin won't read the custom maps unless they are all in 1 custom map folder on the memory card and then you get the too many custom map images because they are over 100 tiles in total.
Any ideas anyone, thanks in advance ?
http://whiter.brinkster.net/en/JNX.shtml
Covers I think what you want, basically need to change format and perform a little patching on the firmware!
I thought you could name them whatever you want, put them on the SD card, then in the settings select which map you want to use.
I believe you can use 2 maps at the same time, but one needs to be called gpsapp... (I am going from memory and can't remember the name).
That's what I do on my 800...have the OS and OSM maps on there.
I don't use custom maps - but have 3 different ".img" files on my SD card on my Edge 810.
I just Disable and Enable which ones I want depending on my ride location and type!
I just pick whatever i want Garmin 800 with Garmin Maps
