The other day when strava played up it seems to have messed up the sync with my fenix. Later rides have synch okay.
So how do I tell either strava or connect to synch 3 rides from earlier in the week?
Usual procedure is Bluetooth phone to fenix. Open garmin connect which the syncs to strava. This worked just now for yesterday's rides but still didn't pick up Tuesdays 3.
Can't see anything obvious which will do the push/pull in either android app
Same happened to me. What I did was to go into Garmin Connect and into the ride in question. Export original then delete them from Garmin. Then just manually import it into Garmin again. You may have to remove it from the zip file first.
That ^
Delete from Garmin connect and re sync. Happens when Strava is doing 'something'
