Rather stupidly pressed Save when I remove my 810 from the bike to go for a comfort break mid ride today. So had to start a new ride after I restarted.
As a result today's effort is showing as two activities, is there an easy way of combining these into one ride?
Cheer I'll give it a whirl...
If you post the .fit files on the Garmin 810 forum I'm sure someone will do it for you.
[url= https://forums.garmin.com/forumdisplay.php?362-Edge-810 ]https://forums.garmin.com/forumdisplay.php?362-Edge-810[/url]
The Garmin edge creates .fit files not .GPX files BTW.
If you can upload the files here I can probably fix it.
Sorry I thought I'd responded - legend's link worked a treat - thanks for both your help...
Bit late, but another way I've done it in the past is upload to Endomondo and use their merge facility, then export the merged ride gpx, import to Strava.
at least you pressed save...there's no way of recoverying the "lost bit" when you forget to hit "start" again...how many times have I ended up with a lovely straight line on my map....DOH!
