Garmin 800 - Bonty ...
[Closed] Garmin 800 - Bonty Speed/Cadence Sensor issue on Turbo Trainer
I've my road bike set-up on a turbo trainer with a Bontrager Speed & cadence senor.
Garmin 800 pairs with the sensor & gives a cadence output on the display but there's no speed reading - what's wrong?
I'm guessing somewhere I need to put the wheel circumference into the Garmin & do I need to switch of GPS or doesn't it matter?
Any help would be much appreciated.
Posted : 26/11/2014 9:33 am
If it works like my Edge 705 then you'll need to switch the GPS off as that will override the sensor
Posted : 26/11/2014 9:41 am
Create a separate bike profile for the turbo and manually enter the wheel circumference.
Posted : 26/11/2014 9:45 am
Thanks for the replies, I'll give it ago tonight.
Posted : 26/11/2014 1:38 pm
speed/distance readings are basically redundant on a turbo anyway, I don't display mine at all
Posted : 26/11/2014 1:46 pm
Won't speed translate into distance (with wheel circumference input)?
Posted : 26/11/2014 2:08 pm
[quote=legend ]speed/distance readings are basically redundant on a turbo anyway, I don't display mine at all
TrainerRoad can turn that into a virtual power reading for a lot of makes of turbo trainer.
Posted : 26/11/2014 2:15 pm
my edge 500 allows me to pair a "speed sensor", a "cadence sensor" or a "speed/cadence sensor". If I select cadence sensor when connecting a Garmin or a Bonty speed/cadence sensor then I will only get a cadence display on a turbo, and if on the road then the speed will be GPS derived and not as measured by the speed bit of the speed/cadence sensor.
Posted : 26/11/2014 2:32 pm
I have this combo, and recently found Bontrager unit to be a pain. All advise above is good. Make sure paired as speed/Cadence sensor otherwise wont work.
Wheel circumference innacuracy wont stop is showing speed, and works on auto fine? I found I had to unscrew the arm adjuster screw and give contacts a good clean, reassemble & position v. close to magnet and screw back tight.
That did the trick for me. Maybe these units are bit unreliable, I have gone back to my Garmin one on turbo.
Posted : 26/11/2014 2:44 pm
Good point, away from TR (or similar packages) I stand by my statement though
Posted : 26/11/2014 3:37 pm
I still couldn't get the speed reading to work so sent the Bonty unit back & bought a Garmin speed/cadence unit - worked first time.
Thanks for the help with the set-up.
Posted : 28/11/2014 6:46 pm
I just took mine of the bike and onto the turbo bike in the summer house. Works exactly the same.
Posted : 28/11/2014 7:12 pm
