Garmin 510 problem ...
[Closed] Garmin 510 problem downloading
[#6483115]
Problem when i plug my garmin 510 into my pc via usb, pc shuts down has anyone else had this problem.
Posted : 14/09/2014 4:30 pm
Does it happen with any other USB device especially ones that appear as storage devices?
Posted : 14/09/2014 4:34 pm
I never connect mine to the PC. I always just sync via Bluetooth to my phone and it auto-uploads.
Obviously this isn't a solution, just a workaround. Sounds like your PC is poorly.
Posted : 14/09/2014 5:05 pm
Does it shut down as in power off or does it reboot? The latter is a driver issue most likely and/or something corrupt in your OS. Is this Windows, and which version? Got all the latest updates and patches?
If it actually powers off and doesn't reboot then it could be a hardware power issue. Is it a desktop, laptop/netbook or tablet? If it's anything working off battery, has it got enough charge, do you leave the Garmin plugged in a while as it will charge off the computer which will drain your battery and shut down?
As for the 510 and Bluetooth, good luck with that. Bluetooth doesn't work for a lot of people and takes forever to get it to pair properly.
Posted : 14/09/2014 5:36 pm
using my cannon camera usb no probs .iff i just plug the garmin usb lead without the garmin connected it does'nt shut down.
it shuts down and does'nt reboot with the garmin connected to the usb lead
Posted : 14/09/2014 6:31 pm
