Future of rear hubs
[Closed] Future of rear hubs
Boost is going to be the most common it seems, but is there still going to be a need for non-boost? On bikes that many still need front mechs perhaps?
The current non-boost size of the week is 142x12 no?
Posted : 30/09/2019 10:25 am
I think they will die out now that hover bikes are here. We'll keep front ones as they deserve it, but the rears will go.
Posted : 30/09/2019 10:29 am
142x12 is the current road standard du jour, so it’ll be around for a bit yet.
Posted : 30/09/2019 10:31 am
Hmm, so a road 142 hub will work on an MTB? What about the freehub differences?
Posted : 30/09/2019 10:43 am
What link are you inferring between boost hubs and front mech capability?
Posted : 30/09/2019 10:45 am
I run a 142x12 hope pro 2 evo (off my 5010) with a shimano HG freehub on my Spesh sequoia, can’t see why it wouldn’t work the other way.
Posted : 30/09/2019 10:48 am
Road HG freehubs are a little wider than MTB and so need a shim to run MTB cassettes. Hope are the exception in that they only offer the road spec freehub on all their HG hubs, and come supplied with the shim that allows use of MTB or road 10 spd cassettes (and the newer 11-34 11 spd road options).
Posted : 30/09/2019 11:07 am
It's limiting bike choice if you like hub gears.
Posted : 30/09/2019 11:22 am
TBF it's the hub gear manufacturers that are limiting your choice of frames.
Posted : 30/09/2019 11:46 am
It’s limiting bike choice if you like hub gears.
Haven’t you both already got frames you like though?
Posted : 30/09/2019 11:52 am
Anything thats "current" just opens the door to some marketing campagin that will tell you your out of date and somewhat inferior. Nothing will stop commercial businesses selling you solutions to problems you dont yet have.
Posted : 30/09/2019 12:00 pm
scotroutes
TBF it’s the hub gear manufacturers that are limiting your choice of frames.
Good point.
tomhoward
I'm alright Jack, but I was thinking of all the other cyclists who will now not have the option to improve their bikes. 🙂
Posted : 30/09/2019 12:21 pm
I have a frame I love yes, but I'll change the wheels soon. I can also change the dropouts to 142 from 135. Now I can still get 135mm hubs, but this might not last. Likewise the manufacturer might stop making dropouts in the future, so I could take the opportunity to gain some future-proofing. However it's only worth it if 142 is actually more future-proof than 135. Plus bolt-through is better than QR generally.
I thought Boost was generally aimed at no front-mech?
Posted : 30/09/2019 12:39 pm
I have 2 bikes with Boost hubs and front mechs. There's nothing specific about Boost that should rule them out.
Posted : 30/09/2019 12:55 pm
A fair few Pivots have boost (and super boost...) rears and a front mech mount.
I think it’s just two trends that have followed each other, rather than ones that are linked
Ah. Boost chainsets maybe....
Posted : 30/09/2019 1:15 pm
Arguably… moving the drivetrain front and rear outboard by 3mm is MORE useful for gaining tyre and chainstay clearance with multi chainring setups than with single ring ones.
Posted : 30/09/2019 1:26 pm
