Hi, I have for sale the following which is all brand new and has come off a new bike I have just brought. All prices include postage.
Rockshox revelation 140mm 650b - the forks are the rlt versions and have a tapered steerer which is 175mm long and have a 15mm maxel which is included. The forks are all black and will come in an original rockshox box and I will supply them with a rockshox air pump. £300
Race face 70mm stem with 6degree rise. Stem is reversible. 31.8 clamp size. £18
Pair of 650b wheels - sunringle inferno rims with a dt swiss 350 rear hub set up 142x12 and has an xx1 compatible free hub and the front has a formula hub with a 15mm axle and the same rim. £200
Wtb volt saddle, this has norco written on it and a green patch on the nose. £15
Fox CTD rear shock in size 7.875 x 2.25 (200x57) this came on a norco sight but I have swapped it out for something I already had. The shock is brand new with no marks or wear at all. Non kashima. £130
Sram XO1 crankset. These cranks are brand new and removed from the sight. The cranks are the alu version and come with the x-sync 32t chain ring. The cranks are the gpx version and have a Q factor of 168. £110
The following items have had minimal use and have come off a recent bike I have split.
Hope 29er wheelset with WTB Frequency I23 Team rims. The wheels are in excellent condition with only one tiny scratch on the rear rim. The wheels are running true and have no dents. The hubs bearings are all in perfect condition as the wheels have only seen around 250miles of riding. The rear hub is set up with 142x12 end caps and the front is a 15mm axle. The hubs are in red. The rims have been sealed using stans yellow tape so are ready to be run tubeless. £220
2012 Rockshox reverb in 31.6. The post is in excellent condition as as been run on a bike I only had for a short period and then has sat in a bag in the garage. The remote cable is 145cm long. The post is 420mm long. £135
For any pictures please email me on chris_hayward_365@hotmail.com as I don't check back to this that often. If I have missed anything then let me know.
Chris
