Front pro 2 forward...
[Closed] Front pro 2 forward and back play?
As above,with the forks locked out,theres maybe 5/6mm play forward and back rocking the wheel gently.
Is this right?
Is it new bearing time?
Lee.
Posted : 17/05/2011 6:46 pm
 flow
Sounds like the pads moving to me
Posted : 17/05/2011 6:47 pm
How old are the bearings and can you rock it from side to side, how does the disc rotor move in the brake?
Loose caliper/mount bolts; loose rotor bolts. What fork/axle?
Posted : 17/05/2011 7:04 pm
Bloody hell!
Just been and had a look and every bolt is loose on my floating disc!
Back one's too,done them up and sorted.
Cheers lads ๐Ÿ™‚
Posted : 17/05/2011 7:12 pm
Did you thread lock the bolts for the rotor?
Posted : 17/05/2011 7:23 pm
