front mech gear cab...
[Closed] front mech gear cable routing on Mega TR
Just got a mega tr frame and it looks like it has a bolt on mech mount (or maybe it's just for a chain guide) but no cable guides on the frame. Is this right or can it be done?
Posted : 03/07/2014 8:34 pm
It is a mech mount and the guides run on the underside of the top tube.
Mine came with a choice of double guides for a front mech and dropper or single guides. Also on the back of the seat tube is a mount that accepts a C clip thing to hold the cable coming down to the mech.
Posted : 03/07/2014 8:56 pm
Yep should be a bag of guides in the box
Posted : 03/07/2014 9:00 pm
Right, still struggling with this. I don't see how the c clip thing on the back of the seat tube is of any use. It needs to be an actual cable stop to tension against... Right?
Posted : 08/07/2014 8:08 pm
Cable stop is built into the direct mount front mech.
Posted : 08/07/2014 8:49 pm
The cable outer will run directly to the front mech
Posted : 08/07/2014 8:50 pm
Just make sure you have a 2x10 mech. 3x10 will foul the swingarm as the cage is longer
Posted : 08/07/2014 9:17 pm
Don't run a front mech. Problem solved ๐Ÿ˜†
Posted : 08/07/2014 9:55 pm
Riiiight, so I do need direct mount. Sorted, ta.
Posted : 09/07/2014 6:12 am
