Front mech cable ro...
[Closed] Front mech cable routing without cable stop!?
[#11041907]
"Help me obi won kanobi youre my only hope!"
Working away so only had the weekend to change my 1x setup to 2x on my gorilla monsoon, lbs booked up for at least a week so thought i would crack on.
Now the gear cable and sheath runs along the downtube from the shifter but then the cable leaves the sheath to enter the plastic routing on the bottom bracket before attaching to the front mech. There is no cable stop so how do i get round this. Im sure there was no cable stop on my salsa vaya either but that was acheived somehow?. Any advice would be very much appreciated!
Posted : 09/02/2020 10:11 am
You mean no stop for the sheath on the Down tube I take it?
Posted : 09/02/2020 10:18 am
Problem solvers make bolt on cable stops
Posted : 09/02/2020 10:20 am
 PJay
null
[url= https://www.sjscycles.co.uk/gear-spares/origin8-clampon-single-frame-cable-stop-black-286-mm/ ]https://www.sjscycles.co.uk/gear-spares/origin8-clampon-single-frame-cable-stop-black-286-mm/[/url]
You can also buy direct mount front mech. adapters and use a direct mount front mech. (the cable stop is part of the mech. itself).
Posted : 09/02/2020 10:27 am
Shimano side swing front mech is needed.
Posted : 09/02/2020 10:36 am
You don't need a stop if the routing is under the bottom bracket...
Posted : 09/02/2020 10:38 am
They only do mtb ones
Posted : 09/02/2020 10:39 am
Depends on the routing/mount but you can buy front mechs (Shimano) that have the stop built into the mech.
Posted : 09/02/2020 10:53 am
 PJay
Sorry, down tube not seat tube. Would you need a bottom pull mech.?
Posted : 09/02/2020 10:58 am
