Front mech 10/11 sp...
[Closed] Front mech 10/11 speed mix
Would an 11-speed Shimano side swing front mech be OK for a 10 speed chain & chainset?*
I know an 11-speed chainset will work OK with a 10-speed chain & front mech as I'm already running that on another bike, but I'm not sure if an 11-speed mech might have a narrower range of motion or not like the wider 10 speed chain?
Thanks. ๐Ÿ™‚
*Edit: or might it be better to run an 11-speed front mech & chainset, but with a 10-speed chain?
Posted : 24/08/2021 5:38 pm
There is an difference in external width between 10 and 11 speed, but its pretty small.
Front mechs are a lot less fussy of perfect set up the rear mechs though. Range of motion will be the same so it should shift fine but it might have a slightly narrower cage which means the chain rubs a bit more when you at either end of the cassette at the back.
Posted : 24/08/2021 6:13 pm
Thanks. I'm asking since Shimano don't seem to do any 10-speed high band, side swing front mechs, but do an 11-speed SLX one.
Posted : 24/08/2021 6:55 pm
