Could anyone help me with this? I’d like to replace the Maxle that came with these - it’s a stealth jobbie with 5mm Allen key but damaged by previous owner. Prob about 2015.15mm non boost.
This any good bud?
https://www.silverfish-uk.com/products/SPARES/Forks/82009005KiT_FOX-Fork-36-Axle-15mm-2015
TF Tuned also have them in stock.
https://www.tftuned.com/fox-fork-36-axle-15mm-2015-non-boost/p3685
Thanks - I just found that too, and have now come round again after fainting with shock about the cost!!
Yeah, bit bloody pricey. Fox tax innit. My burgtec one for my 2021 36 was £30?
Burgtec, Wolftooth, OneUp all do cheaper alternatives
But are any of them for a 2015 non boost fork?
Yeah. Nah.
Rubber_Buccaneer
They used to, I had a OneUp on my N
Non boost Fox
Tell a lie, my Fox must have been 2016, the oneUp non boost is 2016 and later
https://eu.oneupcomponents.com/collections/axles/products/axle-f
The Burgtec Öhlins one looks like it might fit - have emailed them. No idea if any of the above Brand-X ones are correct or not!
Measure the length, thread length and pitch and compare to the brandx ones. They publish all the details. Probably don't even need to measure thread pitch as I'd bet fox always use the same.
It’s the weird stealth bit that is different on the Fox axle - don’t think there is a compatible Brand X one.
For now I’ve jammed and araldited a cut down and bent Allen key in there so it can be manually removed and tightened - reckon that should work as doesn’t need to be very tight. If it fails I will stomach the £65 odd quid!
If it fails I will stomach the [s] £65 odd quid [/s] stem handle bars and various levers
