Front Hub:Specializ...
[Closed] Front Hub:Specialized Hi-Lo disc, 15mm thru-axle service????
I have this hub on my 2009 spec enduro comp, the bearings are showing signs of needing to be replaced but I cant find any information anywhere on servicing them. I've stripped down everthing obvious but am stuck on where to go from here and what bearings I need, they look to be sealed????
Posted : 29/08/2010 7:38 pm
Posted : 29/08/2010 7:49 pm
Posted : 29/08/2010 7:59 pm
Posted : 29/08/2010 9:17 pm
I have a 20mm spesh hub which I eventually replaced as I COULD NOT figure out how to disassemble it!! Neither could my brother. It's just weird.
Posted : 29/08/2010 9:29 pm
doh!
Posted : 29/08/2010 9:53 pm
There must be a way?
Posted : 30/08/2010 7:36 pm
Probably silly question - but are they rebadged DTs?
I have 2 pairs of wheels where the front is
"Specialized Hi Lo disc 28 hole hub with CNC flanges and disc mount. Sealed cartridge bearing and a 9mm DT RWS alloy quick release."
which made me assume that DT built the hub too as the 9mm is not a common standard- although the rear hubs are openly badged as DT?
Probably not I guess - but surely a spesh dealer would know?
Posted : 30/08/2010 8:10 pm
I can't believe no one knows. I don't want to wreck the hub by trying to take it apart the wrong way.
Posted : 03/09/2010 11:47 am
