Free Garmin Edge OS...
[Closed] Free Garmin Edge OS-style maps
[img] http://s22.postimg.org/o6g69q229/final2.jp g" target="_blank">http://s22.postimg.org/o6g69q229/final2.jp g"/> [/img]
If you've got an Edge 800 you'll know that the basemap is useless, and that the official Ordnance Survey Discoverer map is OK, but expensive and cluttered when zoomed in.
TalkyToaster did some good work taking OpenStreetMap data and presenting it in the Ordnance Survey style. I've done something similar, except I've tried to make it a bit clearer (wider tracks and roads, brighter colours etc), and more importantly, I'm not charging for it.
This is my first foray into Garmin mapping so I'll try to update this image as I get more familiar with the map creation tools. The map below is based on the most up-to-data OSM data.
Huge thanks to Nick Pinn for starting me off with [url= http://pinns.co.uk/osm/ ]his OS-style type file[/url] and providing helpful support by email.
[i][b]Download link and installation guide below the screenshots.[/b][/i]
[img] http://s22.postimg.org/yqq3sb6k1/final4.jp g" target="_blank">http://s22.postimg.org/yqq3sb6k1/final4.jp g"/> [/img]
[img] http://s22.postimg.org/po1mla6sx/final6.jp g" target="_blank">http://s22.postimg.org/po1mla6sx/final6.jp g"/> [/img]
[b]Download (~400MB):[/b]
https://www.dropbox.com/s/n5w3h68add8hmk1/OS50.img
[b]Installation:[/b]
Copy directly to your Edge 800's memory card. I see no reason why this shouldn't work on the 810 or Touring.
[b]Enable the map:[/b]
Go to Settings -> System -> Maps and make sure it's enabled. You might want to adjust the detail level as it can get a bit cluttered on levels above "Medium". I'm aiming to fix that it in the next release.
[b]Notes:[/b]
OpenStreetMap data is good but is missing the odd path. It's also not verified and subject to error. Relying on this as a sole navigation source is foolish at best and reckless at worst. That being said, I've not encountered a problem.
Posted : 19/04/2014 10:59 am
Cheers, I'll give these a whirl today. 🙂
Posted : 19/04/2014 11:05 am
Awesome, I see Nick's rebuilt his OS50 style file. I was using the previous version but they were a bit buggy. I'll try recompiling with the new version 🙂
My maps don't have contours yet, that's the next step.
Posted : 19/04/2014 11:13 am
Nice one I'll download these later on and give them ago, normal openstreetmap is a bit difficult to see on the edge 800 screen.
Posted : 19/04/2014 11:14 am
Thank you very much. I've the TalkyToaster ones but will give these a try too
Posted : 19/04/2014 11:22 am
Do you find contours useful on the Edge? I thought they cluttered the map, which is why I left them out.
Posted : 19/04/2014 12:03 pm
Cheers, downloaded and will try on my Touring Plus later.
Posted : 19/04/2014 12:19 pm
Nicely done- will try them out.
Cheers, Paul
Posted : 19/04/2014 2:10 pm
Great work Flaperon. I contacted the guy from talktoaster to ask how to create the garmin files from raw data, he did not respond. Is it relatively easy? As I have managed to create gradient lines (chevrons) and NCN overlays for OSM but not yet got round to garmin'ising it.
Also, massive chapeau for not charging for it.
Posted : 19/04/2014 2:52 pm
For Touring Plus map enable it's
Settings/Trip Pages/Map/Map Information Select Map
Posted : 19/04/2014 4:02 pm
Nice work 🙂
FWI I find contours useful as I then know how much further I have to gasp my way up climbs I don't know well.
Anyone know if this will work on a 605?
Posted : 19/04/2014 6:16 pm
Looks good, I'll give it a go!! Nice work
Posted : 19/04/2014 7:06 pm
 DT78
Cheers will give it a try in a couple of days. Tried navigating soton to Banbury yesterday, very frustrating with openstreetmap
Posted : 19/04/2014 7:10 pm
Cheers will give a try...
Posted : 19/04/2014 8:28 pm
Looks like Dropbox has thrown a tantrum over the data usage. Will try to find a new home for it tomorrow.
Posted : 19/04/2014 8:30 pm
Top work & thank you. Are all Edges the same? Should it work on my Etrex 20?
Posted : 19/04/2014 8:31 pm
 2002
Will I be able to down load and install this using an imac. Looks good.
Posted : 19/04/2014 8:49 pm
yes. I renamed it "gmapsupp" as according to the manuals thats the .img file name the etrex needs to recognise it, and its currently installed via the microSD card in my Etrex20.
Havent had chance to use it yet but cheers to the OP.
Posted : 19/04/2014 8:55 pm
@2002
Yes, exactly how I did my unit earlier today.
Posted : 19/04/2014 9:32 pm
Nice. Can you do the same for Germany?
Posted : 19/04/2014 9:58 pm
@Roter Stern - yep, should be able to but will need to find somewhere new to host the files since Dropbox is limited to 20GB/day.
Speaking of Dropbox, the link should be working again now.
Posted : 19/04/2014 10:12 pm
Cheers, I'll give it a go today, with a ride thrown in.
Do you put the map into a new SD card or does it need to be on the one that comes with the Garmin?
Posted : 20/04/2014 6:32 am
Cool!
I like it, the maps my 800 came with were pants by comparison
for numpties like me, put Flaperons map into the same place as the maps on your SD card, then deselect the other maps from within the Garmin.
easy.
Posted : 20/04/2014 7:48 am
Thanks for the effort and link. Will try here too on my 800.
Posted : 20/04/2014 7:54 am
I've just tried sending this to my Touring and I need another 322 MB of memory.
Will I have to buy another SD card and put these maps on that ?
Posted : 20/04/2014 2:48 pm
Simmy- does your touring have OS maps on it?
You may need a larger card if so.
I picked up a 16gb card, and then moved the OS maps onto it, and all the others.
The menu then allows you to select the appropriate map.
I believe you can also attach a map to a bike profile.
P
Posted : 20/04/2014 3:09 pm
Simmy make sure you copy the file to the memory card not the memory on the unit.
Posted : 20/04/2014 3:13 pm
Just bookmarking for later
Posted : 20/04/2014 4:43 pm
Think I've got it sorted now, it's appearing in the map options so I've just sent a previous ride to the Touring so now time to try it out.
Will report back all being well 😀
Posted : 20/04/2014 4:48 pm
Worked fine for me on my ride this morning.
Cheers Flaperon
Posted : 20/04/2014 5:14 pm
would this work on a GPS60 CSX?
Posted : 20/04/2014 6:12 pm
Probably not, unfortunately.
Posted : 20/04/2014 6:26 pm
Where am I going wrong with this? I've downloaded the Dropbox file and put it onto a new memory card, but it looks nothing at all like the screenshots on here. I've tried altering the level of detail on the maps, but it makes no difference.
If it makes any difference, when I tried to open the file before putting it on the card, it said it was corrupted.
Posted : 20/04/2014 6:29 pm
Try downloading it again? If you're copying it to a brand new memory card, let the Garmin initialise the card before copying it over to the "Garmin" directory.
If you're putting it in the root directory of the card, it probably won't work. Should amend the instructions, really!
To be absolutely clear, it needs to be in the \Garmin\ folder on the card.
Posted : 20/04/2014 6:40 pm
Thank you very muchly, much appreciated!
I have spent the weekend trying to get my head around this Garmin mapping system. Are you able to clear a few things up for me please?
So the gmapsupp.img is a map, correct? When I select and add maps with MapInstall, how does this differ from just copying the .img file directly to the sd card?
I can choose between the maps I've added with MapInstall on the Garmin's menu. How do I choose between the .img files I've added? Surely as they have the same name only one is allowed on the sd card?
Thank you again for the maps, will try them out tomorrow. And thanks if you are able to clear up my badly worded questions above!
Posted : 20/04/2014 7:15 pm
I've downloaded it a few times and tried it, but it's always the same.
Its obviously me, cos I'm hopeless with this kind of thing.
As for putting it in the directory or garmin folder, how do I do that.
Here's what I did, downloaded it, put my new card into my laptop, right clicked on the Dropbox download, send it to new card.
There's no mention of directories or folders or anything.
I need a real idiots guide to things !ike this, which is incidentally why I'm using a new card so I won't bugger the original one up 😆
Posted : 20/04/2014 7:18 pm
I've only gone and bloody done it 8)
And quite easy once you know how.
Many thanks,look forward to trying it this week.
Posted : 20/04/2014 8:02 pm
so talk us through how you did it houndlegs
Posted : 20/04/2014 8:05 pm
Well originally I was just sending it to my new card by right clicking and sending.
I never knew it had to go in a folder- I know very little about computers apart from internet browsing-I didn't even know how to open my new card to see what was on it, so I had a little dig about the internet and found out how to open it, and hey presto there was my garmin folder and ahem 😳 four lots of Dropbox downloads from where I just kept sending them lol.
It was just a matter of dragging one of them to the folder and that was it, and deleted the rest of them. I'm assuming the garmin folder was set up because I'd put the card into the garmin, so I didn't even have to make a folder, which was good cos I've never done that either 😀
Posted : 20/04/2014 8:20 pm
They look good - currently downloading - thank you!!
Posted : 20/04/2014 9:12 pm
 pdw
I'm interested in giving these a try, but can't get at the dropbox link. I have previously been using the maps from garmin.openstreetmap.nl .
I can probably help with the hosting. I run an ISP and we're happy to donate bandwidth to good causes. Drop me an email and we can sort something out.
Posted : 21/04/2014 8:59 am
@pdw - thanks, might take you up on that.
Posted : 21/04/2014 9:31 am
 DT78
Just taken a look on the 800 - looks really nice! Much easier to read.
Question (I don't know much about the 800!) is the map 'routable'? I treid for the first time to follow a route on Friday and it said it was unable to route. Apparently this is due to the base mapping? I was using openstreetmap off talkytoaster
Posted : 21/04/2014 9:55 am
THE DROP BOX THING DOSENT WORK. ANY CHANCE OF GETTING IT FIXED. PLEASEEE
Posted : 21/04/2014 12:10 pm
I'm uploading my version of the Garmin British OSM maps to google drive currently, I'll link to the download when done.
Should effectively be the same as Flaperon's
Edit: Here you go
https://drive.google.com/file/d/0B_uy0wF5v0lbNjEtb0ZOM1BFR2c/edit?usp=sharing
Hope I'm not treading on the OP's shoes 🙂
Posted : 21/04/2014 12:18 pm
Have found new home:
http://maps.androidgamer.org/img/Great%20Britain/
If you download from here can you report back on the speed you achieve? The server is meant to be on a 100Mb connection but I can only get about 450kB/s across the pond.
Cheers,
Dave.
Posted : 21/04/2014 5:06 pm
Flaperon - used them today on my Surrey Hills ride - perfect, so much easier to read than OS maps, linking paths together is much much easier. Also, the scroll and zoom is much faster.
All in all, fantastic. Great work, thank you.
Posted : 21/04/2014 7:02 pm
Thanks for taking the time to produce and offer up the map Flaperon. I used it with my 810 on my commute this morning and looks great, although going through town it was a bit cluttered with bus stops etc. I can't find a de-clutter option on the 810, any pointers anyone?
Cheers,
Jamie
Posted : 22/04/2014 10:07 am
Hi Jamie,
I'm still ripping useless information out of the map but am planning to upload a new version tonight or tomorrow (slightly larger, includes UK and Ireland).
Posted : 22/04/2014 10:27 am
Muchos gracias Flaperon!
Cheers,
Jamie
Posted : 22/04/2014 10:43 am
Uploading now (I'm finding a server in the EU, the SoftLayer dedicated machine is appallingly slow). Typical US-centric mindset of "Well, we can get a fast download from it in Houston"...
Anyway, it'll be at the link above in about 20 minutes.
Changes:
* Significantly decluttered.
* Added newer tracks around Wendover
* It now shows disused canals (the only OSM for Garmin to do so)
Cheers,
Dave.
Posted : 22/04/2014 5:06 pm
 StuE
Hi David
Hope your not trying it out on Thursday!on second thoughts with your track record of map reading it might not be a bad idea.
Posted : 22/04/2014 6:16 pm
Fortunately I have Ordnance Survey maps on there too as a last resort...
Posted : 22/04/2014 7:01 pm
Tried them out tonight - they look fantastic!
I only have a Edge 705 so don't get the full potential with the new mapping screen on the 800, but they look far better than most maps I have tried (and I have tried a fair few!!!)
Thanks again!
Posted : 22/04/2014 9:53 pm
What difference did you have smurfly? I have a 605 so I'm interested. Any chance of a screenshot?
Posted : 22/04/2014 10:22 pm
 pdw
Yeah, I saw very similar speeds. I'm guessing that's an "unmetered" 100Mbps connection, in which case it's not surprising that you don't see anything like 100Mbps.
I've temporarily stuck a copy here for now:
http://sphinx.mythic-beasts.com/~pdw/OS50/
which should be much faster, particularly in the UK. I'm still happy to help with some free bandwidth for the project if you're interested.
I had a chance to play with the previous version on a couple of rides yesterday. Overall I think it's a big a improvement over the previous OSM maps I was using. The wider roads, road colouring and large place labels in particular are a great improvement.
I'm less sure about the dotted lines for FPs and BWs because the Garmin does a particularly poor job of rendering them, and I was undecided about the diagonal shading for national parks. I was riding in the Lakes so you see quite a lot of it 🙂 The only other issue was if you zoom right out the view gets very cluttered by all the fells.
Keep up the good work 🙂
Posted : 23/04/2014 8:57 am
Hi pdw,
Thanks for mirroring the maps. I should have a server sorted in Amsterdam within a few days which will solve the problem (Softlayer have got to move the existing stuff from Dallas).
There's plenty of opportunity for tweaking. I may remove the national park shading altogether, since it doesn't accomplish any practical purpose on the GPS. I left it in because I find it handy to quickly find places in Basecamp, and it disappears at higher zoom levels on the Garmin.
How would you change the lines for FPs / BWs? I've made it slightly bolder than the original style but more or less left it unchanged. I was going to make it magenta but decided that it would conflict with Garmin's own route track.
I could add diamonds to bridle paths (a la OS recreational routes) to make them clearer? Or, alternatively, change the colour of footpaths? Or add a black border to the bridle path so it looks more like a road?
I'll make up a few examples at the weekend. You can only have two colours on a line which makes finding a compromise difficult.
Dave.
Posted : 23/04/2014 9:12 am
this is great, bookmarked for later.
Posted : 23/04/2014 9:25 am
Great work Flaperon and thanks for the mirror pdw- downloading as I type! I feel the footpath / BW styling is just about spot on (on the 810) FWIW.
Spurred on by your good work I managed to mkgmap of Belgium yesterday for the first time- any chance of uploading your TYP file to see how it works on foreign shores?
Cheers,
Jamie
Posted : 23/04/2014 9:33 am
Jamie - I've modified both the TYP file and the style itself so one probably won't work without the other and inconsistencies throw mkgmap into a panic.
I can build a map of Belgium for you using this style when I get home this weekend if you want.
Posted : 23/04/2014 9:56 am
Flaperon - great work - by far the clearest map set. The only issue is that a number of cycle routes don't appear on the map (or am I doing something wrong?) in particular the one missing seem to be the old disused railway track type. Any chance these could be added?
Once again thanks for doing this.
Posted : 23/04/2014 10:37 pm
 pdw
I think the issue with the FP/BWs is that the dots are relatively short and wide with big gaps between them making it hard to see how they join together to form a line, particularly at junctions of multiple paths. The other OSM maps that I have does alternating dark/light grey which maps it a bit clearer.
For example, the paths in the woods on the left screenshot are quite hard to decipher, whereas (ignoring the poor contrast between grey and green) the tracks are clearer on the right hand side.
[img] [/img] [img] [/img]
How about alternating between orange and light grey? Or just going for a solid, but relatively narrow line?
Posted : 23/04/2014 11:47 pm
That'd be great, thanks muchly! We're riding to Bruges via the Channel Tunnel from next Wednesday so ideally I'd need north France too.
Cheers,
Jamie
Posted : 24/04/2014 10:24 am
But then it wouldn't look like an OS 1:50,000 map, would it 😀
Here's a screenshot from my 810, I think its clear enough.
Of course, zooming in a little more makes things much clearer.
Cheers,
Jamie
Posted : 24/04/2014 10:49 am
This looks really interesting. Quick question on memory cards - I've got 3 cards on the go, one with the OS Maps that came with the unit (I think there's some sort of copy protection on this one) one with a city navigator copy and one with osm for Spain. If I get a big micro SD, is there any way to have all the maps on the one card and select from a menu on the garmin 800??
Posted : 24/04/2014 11:03 am
Petrieboy it's my understanding that you can in the menu and maps list.... I only have the 705 and the map image had to be named GMAPSUPP.img so only one map can be used!
Pretty sure it was an upgrade on the 800.... Sure someone will correct me
Posted : 24/04/2014 9:36 pm
on the 800 (and the etrex20, we have both) you can have multiple maps on a card and choose between them.
Posted : 25/04/2014 10:26 am
Much better imo many thanks to OP
Posted : 25/04/2014 3:27 pm
 pdw
Well I think a solid narrow purple line would look closer to an OS 1:50k bridleway than the Garmin's attempt at a dotted line.
But it comes down to what the OP is trying to achieve. I like these maps because generally they look better and clearer than other OSM-based maps, not because they look exactly like OS maps, so personally I'd be in favour of a bit of divergence from OS style in the name of clarity.
Posted : 26/04/2014 7:58 am
 rob2
Just loaded. Much clearer on a garmin 800. I'll be trying out soon. Thanks OP
Posted : 26/04/2014 10:00 am
Update:
New home found on an EU server - I maxed out my 80Mbit connection so you should get decent download speeds now.
http://maps.androidgamer.org/download/
I'll update the maps shortly, will try a clearer route for bridleways, probably magenta and grey or something similar. At some point I'll add the whole of Europe once I'm happy with the colour scheme.
If you're mirroring the files I'd be grateful if you just redirect to my own server now - grateful for the help but for version control would prefer just the one source.
Posted : 01/05/2014 12:48 pm
FYI I have been using your maps for a week or so on my edge 705 and as lovely as they look I've had to go back to the plain osm boring maps.
Obviously the edge 705 doesn't have the same mapping screen as the 800 so a lot of the roads appear in segments rather than one flowing road, but the major issue for me was the 705 places my route underneath the road, and with the thickness of the roads on your design blocks the route out and it can't be seen.
If anything it's urged me to save for an 800, but the 705 just isn't up to it comfortably..... Unless I am using it wrong
Posted : 02/05/2014 9:20 pm
Would love to try this map on my new 800 as I'm not that keen on the garmin os maps.
Can anyone post an ebay link or similar to a micro sd card that I can buy to download this map onto? Thanks.
Also presume the new map is good for off road and can use bikehike to plot maps etc?
Cheers!
Posted : 03/05/2014 8:35 am
Thanks again to the OP for his work.
I just loaded it to my 605 and thought I'd post pics of how it looks compared to the talkytoaster ones.
This is the OP's new OS-style map:
This is the same place on the talkytoaster map (with contours, routable)
For me, I think I still prefer the talkytoaster one as it has contours which I like to see but otherwise, it is good though as someone previous pointed out, roads seem to cut over eachother at juntions rather than just being continuous lines - you can't see it in the pic above, but at t-juntions, I found a lot of roads overlap in a way that makes it confusing - less of an issue out of town though where roads are less densely packed.
Posted : 06/05/2014 10:30 am
flaperon, I gave these a good test at the weekend whilst riding the Welsh Ride Thing. I think you may have some data issues with your OSM load and/or tagging as I found several missing roads which I think is unusual given the current coverage of OSM. I am wondering whether you are missing a tag type?
Sadly, I was so utterly wasted most of the time I did not manage to note which ones.
Posted : 06/05/2014 10:50 am
 Nick
Likewise I used them on the WRT and they were fine as I was using my route to navagate with rather than the map and I was with two others who also had mapping GPS (Official OS), however as David says there were some roads and tracks missing that were on my companions devices.
Still a great piece of work though so thanks very much for pulling it all together.
Posted : 06/05/2014 11:01 am
 Bez
Interesting. So you can take OSM data and produce maps in a custom style... Are these routable on an Edge 800/Touring? Is there any information kicking about on how one might do this? I'd be keen to make some really stripped-back maps for road riding if they work (and, less likely, if I have time...)
Posted : 05/06/2014 12:33 pm
Thanks to the OP and the updated image on the 80Mbps host. Downloaded on to my Edge 800 last night and took it out for a trail session in the pentlands around Edinburgh this evening worked a treat and what a difference to the stock maps. Brilliant and saved me a wee fortune for the garmin equivalent.
Posted : 23/09/2014 9:19 pm
Firstly thank you Flaperon for producing this map, it's very clear and works much better all round on my Edge Touring Plus, including improved rendering and battery life too.
I just wanted to ask a few questions:
- is the link at the top of the first page of this thread kept up to date, or should I download (for UK) from one of the other links later on in this thread?
- how to use this map in Basecamp so I can plot a route (it's not clear on this thread if that's possible or not)
- is there an application that's better than Basecamp for plotting routes, where it allows you to create a route by simple clicks on the path/road, and it plots a sensible route for you?
Thanks,
Phil.
Posted : 16/04/2015 11:38 am
I use bikehike (which you can manually create waypoints joined by straight lines) or bikeroutetoaster websites (which can "auto-route" between waypoints using openstreetmap data).
For off-road stuff, auto-routing doesn't work very well though, better just to use bikehike to create waypoints (overlayed on OS maps on the website) linked by straight lines.
Also, thanks for posting the Q as i missed this thread the first time round. Cheers for the maps Flaperon!
Posted : 16/04/2015 11:48 am
