Anyone know of somewhere I can get some welding done on a frame ? Im near Oxford and its Aluminium.
I have broken one of the ISCG tabs off and need to get it put back on as soon as possible ๐
I always understood that welding an aluminium frame was a no-no...?
It can be done. However teh final strength of the repair and the metal around the repair relies not just on the skill of the welder but on the type of aluminium that is being welded.
It might need heat treatment afterwards and a proper repair will be expensive. For an iscg tab I personally wouldn't bother - I'd be looking for a different solution
This was just posted up in another thread
http://www.chainreactioncycles.com/Models.aspx?ModelID=11453
could be a solution if the old tab can't be fixed.
Which was why I thought welding alu wasn't a goer...
The broken tab will need to be welded back on, its integral to my Hammerschmidt. So long as its welded on flat like the other two that have not broken off it should be OK.
Can you recommend anyone ?
you might try
vulcandezign guy called Jo White
vulcandezign@yahoo.co.uk in wheatley
i suspect you will need to get the bb faced and thread chased after
Thanks Ade, I will check them out tomorrow.
If its just one of the three lugs thats broken off, just get the area built up with enough weld so you can drill and retap the hole, get whoever does it to build a fair bit of "meat" around where the new hole will be then file down the shape just to tidy up, reface and chase thread. I had this done a couple of years ago and its still going strong.
