My frame is being replaced under warranty, not with an exact match, but with the one from the following year; as a consequence (maxel) I need a new back wheel, which they have offered. All other bits are to be swopped from the old bike by the LBS for the princely sum of £25.
Anything I should be wary of or need to check on the deal before saying yes?
New frame and wheels is likely to have a shop value of £1200, any scope for turning this into a discount on a new bike, from the same manufacturer obviously?
Bump
Surely somebody has something to say
Obviously bike make/model helps but without knowing that, i'd say thats cracking service from both LBS and manufacturer.
Yea, tend to agree, just seeing if anyone had any bad experiences with this sort of deal
I'd be watching little things liek headset compatibility, but given th eMaxle thing, it sounds like that's all covered.
Not uncommon for replacement frames to be the next model up in the range either. Either way, sounds like you're being well looked after.
Sounds like a good outcome to me.
