Frame builder recom...
[Closed] Frame builder recommendations to fit Paragon dropouts to existing frame
I thinking about getting Paragon Sliders fitted to my Cotic Solaris and wondered if anyone had done similar to a steel frame and could recommend someone to do it? Cheers
Posted : 23/06/2017 7:55 am
Ben at Kinetics in Glasgow did this very thing for a mate of mine.
Posted : 23/06/2017 8:14 am
Hi Bedmaker, any issues or a complete success?
Posted : 23/06/2017 8:43 am
Well, I ran out of coffee, which was disasterous ๐Ÿ˜€
I'm not doing frame repairs and mods at the moment, too much other work to do...
Posted : 23/06/2017 8:50 am
I presume the Solaris is powdercoated like older Cotics? You might need to allow for a strip and re-coat as well. Get it dipped before you take it for modification?
Vernon Barker in Dronfield could do the welding/brazing and I'm sure he'd make a good job, but I think he only does stove-enamelling not powdercoating. He did some good work on an old Kona for me a few years ago.
Or try 18 Bikes in Hope if their workbook isn't full, maybe?
Posted : 23/06/2017 11:06 am
Pargons are quite substantially different to cotic dropouts, i doubt it would be an easy swap. Unless you want the back end 2" longer that is.
Posted : 23/06/2017 11:47 am
Spoken to Jon at Chicken Frame Emporium and he's done a number of similar jobs and we've decided on rocker dropouts for the reasons you say STATO.
The alternative is to look at Curtis XC9 built to Solaris geometry
Posted : 23/06/2017 4:03 pm
Get one of these if you want to run SS, would save you hacking your frame.
https://www.bike24.com/p246223.html
Posted : 23/06/2017 7:46 pm
 LeeW
Doug Pinkerton has done a few bits for a mate of mine.
Posted : 23/06/2017 7:55 pm
 ctk
Yep Trickstuff EBB or White Industries ENO hub. Much easier, or sell the Solaris and let Chickens build you a whole frame!
Posted : 23/06/2017 8:10 pm
makes note to stop sending nutjobs to Ben ๐Ÿ˜‰
Posted : 23/06/2017 9:43 pm
๐Ÿ˜€
Common Wheel have now got an oxyacetylene torch and they've just about worked out which end to hold, so I'm planning to send them nut jobs to them...
Posted : 23/06/2017 11:11 pm
