FOX Vanilla 130r se...
[Closed] FOX Vanilla 130r service, easily done yourself or send away?
I have a set i've been running for about 10 years now and they're in need of a good service. question is do i buy the seals and oil and do it myself? or just spend £90 ish and send em off to Mojo?
i'm pretty good at bike building/servicing other bits but never tried forks?
so is it a piece of cake or a right old git!
Posted : 31/05/2011 9:48 am
Depending if the bushes are borked or not... if so, send away (TFT, not mojo) otherwise, do it at home.
Posted : 31/05/2011 9:51 am
there's a slight knocking sound so the bushes are probably gone 🙁
Posted : 31/05/2011 9:52 am
TFT then
http://www.tftunedshox.com/index.php
Posted : 31/05/2011 9:55 am
so why TFT over Mojo? I thought Mojo were the fox specialists? ❓
Posted : 31/05/2011 9:56 am
Hold on, didn't those fox forx always knock slightly? vague recollection that they were designed that way for hydrostatic lubrication (or I may be making it up totally...)
Posted : 31/05/2011 9:57 am
TFT - great customer service
mojo - seem to think they're doing you a favour in doing anything for you...
Isn't a hard choice for me.
Posted : 31/05/2011 9:58 am
LoCo Tuning would be my recommendation if they need a serious look at (bushes etc).
If it is just an oil and seal change then it is easy to do yourself (it a little messy!). Have a search for instructions on how to.
Just as an aside if they are 10 years old then you may be best buying another s/h pair - sad but true as oil (£15) + Seals (£14) + Crush seals (£2) + Float Fluid (£2)+ other item you need but don't have (£5) will cost a fair bit and you will still have a rather tired set of forks. Reasonable condition s/h Vanillas can be picked up for about £80.
Posted : 31/05/2011 10:01 am
Thanks for the advice guys, as far as condition go? they have been well looked after and are buttery smooth, and Cutter....by reading a bit of TFT's site they were designed to knock slightly so maybe just an oil and seal change needed 😀
there's nowt wrong with them so don't see the need to ditch them for another set which i have no idea on history.
Posted : 31/05/2011 10:47 am
Fair enough, if they are still in good condition and knock is typical then doing it yourself would be my recommendation.
Posted : 31/05/2011 10:52 am
