fox triad bottom bu...
[Closed] fox triad bottom bush dumb ass question
3 Users
hi all.got a bit of play in the bottom bush.
replace the du bush.
or does the axle pin need replacing as well.
cheers guys
Posted : 19/04/2010 8:27 pm
Sorry to say it could be either. The DU's are designed to wear 1st but I went and bought some new reducers and DU's from Mojo as I normally would only to find it was the pin. If you have a friend local to you with the same bike try your pin in his and vice versa. Then you'll defo know.
Posted : 19/04/2010 9:15 pm
 LoCo
Replace both as the original spacers aren't great, and most likely have worn a bit so will wear the new DU bush at an accelerated rate.
Better to sort it properly first time. The lower bushes/spacers do wear quite quickly in an fsr linkage due to being in the line of dirt off the back wheel and the rocker link setup.
Posted : 20/04/2010 8:52 am
cheers guys...both it is then..nice one.
Posted : 20/04/2010 7:08 pm
