Fox RP23xv Notch
[Closed] Fox RP23xv Notch
2 Users
I've got a Fox RP23xv which has been serviced at regular intervals (seals) I've come to notice that at the start of the stroke it seems to have a small step before getting into its smooth travel. I have removed the shock and made sure this is not coming from the bearings/pivots in the frame. This seems to happen with ProPedal both on (all 3 settings) and off.
Has anyone else experienced this and if so what was it and how was it fixed?
Posted : 09/09/2011 7:16 pm
Mine does the same, non xv model though. The only servicing it's had in 3 years is removing the air can for a quick clean and fresh blob of Float fluid.
As it's normally sat in a sag position, passed the 'notch', I've never really given it too much thought!
Posted : 09/09/2011 7:41 pm
