Fox RP23 - Propedal...
[Closed] Fox RP23 - Propedal settings 1, 2 ,3 - Knob turning question
4 Users
When changing the propedal on an RP23 shock from setting 1 to 2 to 3, do you always have to turn the knob clockwise, when the lever is in the propedal position? To get from position 3 to 1, you just keep turning clockwise?
Posted : 21/04/2010 8:40 pm
No idea...note on instructions just says the ProPedal should be on when you make the adjustment (and if you look at the Fox manual photo the shock has the air valve to the right of the dial, but in real life the air vavle is to the left (so when it says turn away from the valve, which direction are you going? I know which direction away is but the photo doesn't match reality so does away from valve turn it off or on? I assume it's off as it certainly makes my shock more active!)
Posted : 21/04/2010 8:51 pm
No Pro Pedal should be OFF when you make the adjustment! Lever goes clockwise to turn on.
Posted : 21/04/2010 8:55 pm
