Might apply to RP3 as well
What are you running?
The pressures in the Pitch manual seem high to me
With your bike should have been a little 'Sag-o-meter' which you use for setting the sag on the shock. There's a video on the Spesh website showing how to use it, but basically it measures the sag on the shock from the shock body to the O-ring neatly for you. It's easy to use, and it works
http://www.specialized.com/bc/microsite/suspensionsetup/main.html?x=y
TBH I couldn't tell you what's in mine.....
What peter said...
it isn't locked out is it 😉 ...it has been known!
175psi in mine (14stone of pure northern hemisphere bulk) uses most of the travel when fully open.
Cheers all
It doesn't lock out so it's not that!
No sag-o-meter but the O-ring is there so I'll just have to play around with some pressures.
