20mm through axle f...
[Closed] 20mm through axle fork
[#618021]
dont mean to sound like a complete numpty
but im using regular QR fork just now
if i go for something with a 20mm through axle will
i need a new hub ??
Posted : 09/06/2009 1:30 pm
 jfeb
Yes, unless you have a hub that can be converted e.g. Hope ProII
Posted : 09/06/2009 1:35 pm
depends on your hub. Certain hubs you can buy a converter for to switch to 20mm Hope Pro2 and Halo both do this but if its a cheapish wheel its likely you will need a new hub or wheel.
Cheers its a Hope hub but not pro 2
looks like a new hub or different forks
oh well
Posted : 09/06/2009 1:49 pm
go for a new hub, the upgrade to 20mm isn't one you'll ever regret!
Posted : 09/06/2009 6:44 pm
is it a BULB ?? (that'll convert)
rough rule of thumb, how thick is the central part of the hub - does it look like it'd [u]easily[/u] accommodate a 20mm axle?
(edit - better still, get on hope's site & see what it is)
Posted : 09/06/2009 6:57 pm
