Fox Kabolt torque a...
[Closed] Fox Kabolt torque and front hub premature bearing wear?
I own a DT Swiss wheelset (240 hubs front and back) bought new with around 800 miles on them. This is the second set of these hubs that I have owned. The front hub has started to get a bit notchy which is really surprising as I though the Japanese-made bearings in these could go for 1000's of miles before needing attention. Indeed, my last pair never needed anything doing to them in the thousands of miles I put on that bike before I sold it.
The only variable I can think of is that on my current bike, I'm running a Fox 34 fork with the Kabolt through axle. The torque spec on the axle is 17nm, which I consider to be really high for a through axle. I set it at 15-16nm just to give a bit of leeway but I have seen some of the newer Kabolts with a torque rating of only 9nm.
Has anyone else run into the issue of premature bearing wear with this setup? Should I dial down the torque on the Kabolt?
Posted : 21/02/2021 4:14 pm
I'd think its unrelated as all the torque is being applied to both sides of the inner race of the bearing and not side loading the bearing.
I couldn't tell you what torque I use on my kabolts, one-up axles etc but it's 6mm Allen key tight and isn't coming undone on its own if that's any quantifiable measure?
Power washing aside, I reckon the most underappreciated killer of front wheel bearings over here is wheels spinning endlessly on vertical hitch Mount bike racks on the drive between riding locations.
Posted : 21/02/2021 4:48 pm
Nsmb/one-up agree 17nm is excessive
Posted : 21/02/2021 4:54 pm
I’d think its unrelated as all the torque is being applied to both sides of the inner race of the bearing and not side loading the bearing
Very good point, I didn't think of that.
@BearBack - great article, thanks for the link. I'm going to wind down the torque quite a bit and see how it goes.
Posted : 21/02/2021 5:07 pm
