Fox IRD app setting...
[Closed] Fox IRD app settings / rebound calculations etc
so just used the app for my forks and shock
it worked and picked up the o-ring spot on on both my forks and shock
however, as im quite light i guess, it suggested the rebound on my shock i should not bother to have any, ie, all 14 clicks out to fastest setting? does this seem right?
on the forks its suggested for my weight/o ring position that i have 9 clicks from fast from a possible 18 so seemed to want to offer me some rebound in that case
gonna give it a shot, as i was only running 130psi in my rear shock, and now ive used the app im upto 190psi, which immediately has stiffened up the rear end, especially more noticeable in climb mode which i like!
ive upped the front forks from 65psi to 90 too, so gonna give it a shot
so question really is, why has it told me to have no rebound damping on my rear shock? is it just because im a lightweight ish rider or similar? surely i need some?
Posted : 27/12/2013 10:38 am
anybody used this yet?
Posted : 27/12/2013 12:32 pm
Tried but ios only then worked out its just giving you standard table settings. See them as a starting point ride and try more or less from there.
Posted : 27/12/2013 12:38 pm
cheers mike, yeh not used it before so thought i'd give it a shot
cant really understand why it would suggest no rebound damping though, as said putting a bit more air in will certainly help stiffen up climb mode for me (which it has done)
will have a ride out on the settings tomoz and see how they feel
Posted : 27/12/2013 12:45 pm
