Fox float suspensio...
[Closed] Fox float suspension fluid
[#3495815]
I'd like to service my Fox float 32's and have just found the correct oil volumes on [url= http://service.foxracingshox.com/consumers/Content/Service/oil_volumes.htm ]foxracingshox.com[/url]...
it says I need FOX Green 10 wt & FOX Float Fluid, do I need to go out and buy the specific FOX Green 10wt fluid? Or will any old 10wt. suspension do the trick? Seems like I'd be spending double to get the stuff FOX specifies - does it make much difference? What is the difference between FOX green and red 10wt?
Also - how often (milage or time) should FOX forks be serviced?
Dave.
Posted : 27/12/2011 11:43 am
Just buy any motorbike fork oil, as long as its the same wt.
You do need to get the Fox float fluid though, its really weighty oil and is only used on the foam ring, so it goes a long way.
Posted : 27/12/2011 11:49 am
cheers - just bought some of that fox float fluid in bulk
How often (miles or age) do they need servicing?
What is the difference between fox green and red fluid? (both 10 wt.)
Many thanks
Posted : 27/12/2011 12:35 pm
There is a difference between Green & Red relating to its viscosity at temperature and how that would effect its damping properties. So if you want to follow Fox advice then it is there for a reason, albeit a very technical one. Many people experiment with different types and brands though from Synthetic motor oils to automatic transmission fluid. You won't risk damage at the approx correct viscosities though you will change the characteristics of your forks performance
Posted : 27/12/2011 1:43 pm
 Taff
AS an amateur I probably wouldn't notice the difference between the oils as stated by reboundsuspension but I do prefer Rockoil in comparison to Silkolene. I do have some fox stuff leeft but don't use it. You can change the oil as often as you like but I would say if you cover a lot of mileage it may be worth changing the oil every 6 months and doing a seal and oil change every year. Change the deal after the crappy winters have passed
Posted : 27/12/2011 1:53 pm
