Hi,
When braking when going quickly i noticed that the handle bars shake forward and back pretty quickly. I notice this more when i ride on the road on my mountain bike. I have tried swapping the headset bearings with my other bike but the shake is still there. I think the only other thing it can be is the fork bushing? The forks work fine, they are the Fox Float RLC model. No noticeable play when the test it when the bike is stationary.
Also i only really notice it when the forks are locked out...
Anyone know where i can get the bushings to replace the ones i have probably worn?
anyone?
if you are near sherwood pines, i think dale the mechanic can replace them.
I live south of london.... Do you think he can sell me some bushes? Recon i can install them myself.
if you lock the front brake on and rock the bike can you feel the forks knocking?
if you turn the front wheel so it's at 90 degrees to the frame and repeat is there less movement?
You need the correct tools to remove/fit to the correct depth and size the bushes.
The knock maybe a base valve issue
@ loco :- can you service stratos shocks?
wwaswas, i will try that tonight. From memory there was little play in any direction when the bike was stationary. Just when it was rolling the handle bar starts to shudder when i start braking.
Loco, I could make up some tools. I have a lathe and lots of tools. But will see how much it will cost for someone else to replace. I dont think its the base valce, as the shuddering is when the forks are locked out.
no don't do stratos stuff.
Hi LoCo,
Didnt realise you servised forks for a living. So its £45 to replace the bushes, £18 to post the forks back?
£13 to post back. Cost is in conjunction with a full service would be a little more for just bushes. drop me a mail 😀
Hi,
Turned out the the rotor was lose on the hub so thats what caused the shaking. All fixed now 🙂
cheap fix!
Cool, enjoy 😀
Lucky lucky lucky!
