Fox Float DPS sag -...
[Closed] Fox Float DPS sag - losing pressure?
 merk
I can seem to get my Fox Float DPS shock below about 32% sag. The bike is only a week old and has had this issue since day one. Does anyone have any ideas?
The pressure reading on my pump makes no difference, sag won't go below about 32% even if beyond the recommended pressure (175 psi)
My digital pressure gauge shows about 147psi constantly - less than what it should be.
I compress the shock every 50psi as stated.
No matter what I do though, I can't get lower than just above 30%!
Posted : 16/05/2020 7:43 pm
Cover it in (slightly watered down) washing up liquid. Any leaks will be visible right away
Posted : 16/05/2020 11:18 pm
