Fox float CTD , Rep...
[Closed] Fox float CTD , Replacement for an Rp23
3 Users
Hi ,
My Rp23 started spewing red oil from behind the damping knob .It seems one of the seals is gone .
Its going to cost me €130 to get it fixed .
I see a New Fox Float CTD for €110
Is this a better shock , will it fit my bike and be a good replacement ? anything I should look out for ?
Cheers ,
J
Posted : 09/08/2017 1:44 pm
Ok I see now that I have to get an exact match for this shock so the ceap stuff on ebay is out and getting the shoxk serviced is the way forward
Posted : 09/08/2017 4:37 pm
My RP23 started sounding squelchy so used the same logic as you and bought a used CTD. Obviously the length and stroke have to match the old one, but I figured getting the correct matching custom tune was probably impossible so ended up with one tuned for another make of bike (4 digit code on shock)
Overall still a vast improvement. I did get an LV can rather than matching the old HV one and it now has much better support.
The Climb/Trail/Descent lever is fairly subtle in its operation so dont expect a full lockout on climb.
Posted : 09/08/2017 8:28 pm
I found the CTD a distinct downgrade from the RP23. On either I'd recommend getting it pushed/shimmed/tuned for your bike as part of a service.
Will depend on the bike of course but a tuned shock will nearly always be a vast improvement on an off the shelf tune.
Posted : 09/08/2017 9:25 pm
