Do any F120 owners get anywhere near 120mm travel out of their forks?
I don’t expect to get 120mm all the time but I’m not getting any more than my Float 100’s on my other bikes.
Before I send them to Mojo I wondered if the last 20mm of travel is saved for when you fall off a cliff or something?
The set-up guide says I should be using about 95psi for my weight.
But I can only manage 100mm travel with about 50psi and 120mm with about 15 psi, which is crazy as the forks squat about 35mm under their own weight.
I’ve taken the airspring out and checked, but there’s no rouge spacer.
Any ideas?
I only get 80mm on my F100s unless they are setup sagtastic.
I thought it was normal this kind of thing (though perhaps disappointing). My Reba WC 80's only give 65mm....
