Fox DU Removal Tool
[Closed] Fox DU Removal Tool
7 Users
Hi,
Need to replace the bushings in my shock and was wondering if anyone had the DU Removal Tool?
http://www.mojostore.co.uk/acatalog/Fox_Rear_Shock_Bushing_Kits.html
Be will to pay for postage each way and put £30 into a paypal account (as insurance) while I use it to replace my worn bushings and then return.
Posted : 26/03/2012 11:37 am
Ask at your local bike shop if they have a freehub body bolt from a Shimano hub. It's the perfect size for pushing the DU out in a vice (into a socket).
Posted : 26/03/2012 11:42 am
if you have a small socket set check them, as one of my small sockets fits perfectly, then as above push out into a much bigger socket via a vice
Posted : 26/03/2012 11:44 am
Got loads of old Shimano hubs kicking about. Which Bolt we talking about?
Posted : 26/03/2012 11:45 am
Try one of these for 12 quid including postage. They also do cheap bushings.
[url= http://www.stephenscycles.talktalk.net/Tools.html ]http://www.stephenscycles.talktalk.net/Tools.html[/url]
Posted : 26/03/2012 11:46 am
Will you be using the tool with a vice or without one?
Posted : 26/03/2012 11:48 am
i got Vice's 🙂
Posted : 26/03/2012 11:49 am
 sv
There is one on eBay for under £10 delivered, works very well.
Posted : 26/03/2012 11:50 am
The massive hollow bolt that attaches the freehub body to the hub, at bottom right of this image:
The flat, non-threaded end is a perfect fit and better than a socket as it isn't rounded.
+1 for the £12.00 one of eBay, got one last week. The supplied bush only lasted 1 ride on my Remedy though, I think I need to replace the alloy hardware. 🙁
Posted : 26/03/2012 11:52 am
 sv
that's what I am replacing (Trek Remedy 9)RP23 (4 years old and first time replacing)
Cheers Chaps, I'll get my hardware ordered today and a hub dismantled
Posted : 26/03/2012 11:55 am
The vice specific tool are much fater and realistically it's what all the pro mechanics I know use in the work shop.
The smaller tools you get from ebay are OK, however I had problems with the threads on the screws / bolts getting damaged easily.
Still once you have the tool sorted you can fix loads of other riders bushes for beers 😀
If the tool you make removes any of the bushes lining I would simply buy an actual tool.
Goodluck!
Posted : 26/03/2012 12:01 pm
So i used the Bolt from from the Shimano Freehub body, with a vice, worked like a dream. Big thanks to Thrre_Fish for the tip.
Posted : 01/04/2012 5:13 pm
