Fox 7wt oil - any o...
[Closed] Fox 7wt oil - any other alternatives that are the same/offer same properties?
Fox is £13 for a little bottle, is any other 7wt the same that i can get easily?
Posted : 04/04/2010 8:33 am
Any motorcycle fork oil of similar weight - try halfords or a motorcycle shop
Posted : 04/04/2010 8:38 am
Silkolene Pro RSF 7.5WT
Posted : 04/04/2010 8:43 am
http://www.chainreactioncycles.com/Models.aspx?ModelID=112
This stuff i use in marzocchi mx comp's and its really good.
Posted : 04/04/2010 8:49 am
i used silkolene rsf after getting recommended it. I use 5 and 7.5 mixed 50.50 instead of sus fluid and been using the 15 stuff for float fluid. But as im trying to isolate a prob with a set of talas i bought proper float fluid yesterday 8 quid odd at edinburgh bikes in the sale this weekend
Posted : 04/04/2010 11:33 am
it amazes me that some people will spend hundreds of pounds on suspension but try and save a few quid on the right oil to make them work properly.
buy what the manufacturer specs, they spec it for a reason and its not profit. they've already made their margin out of you....
Posted : 04/04/2010 11:44 am
Really?
I bet the margin on the consumables is much bigger than the forks. Have a look at Shimano brake fluid prices compared to the matching LHM fluid from a motor factors.
Posted : 04/04/2010 11:46 am
jambo the silkolene in the 5050 mix is bang on manufacturers spec
Posted : 04/04/2010 11:49 am
 gamo
[url] http://www.peterverdonedesigns.com/bikesuspension.htm [/url]
fox seemingly rebranded RSF.
Posted : 04/04/2010 12:30 pm
Torco RSF Medium to be precise.
http://www.nimbusmotorsport.com/ProdShop2.asp?id=731&CATID=308
Posted : 04/04/2010 12:38 pm
Mainly want to buy local instead of save money jambo to be honest 🙂 as there is a motorcycle shop next to jeJames it doubles my chance of getting the right wt
Posted : 04/04/2010 1:01 pm
 LoCo
Any decent 7wt stuff will do the job, however some are a bit better the others personally Motul Factory line oil is what I use, so do these chaps
http://www.k-tech.uk.com/store.php?category=34&PHPSESSID=64dcff8b43d10f4f1bada501db645fa9
Fuch,Torco,Castrol or any of the other well known brands are good to.
Posted : 04/04/2010 1:34 pm
tim flooks does some good stuff, uses it for all their services I believe:
[url= http://www.tftunedshox.com/Additional-Departments/Oils-and-Grease ]http://www.tftunedshox.com/Additional-Departments/Oils-and-Grease[/url]
Posted : 04/04/2010 2:54 pm
