Fox 36 Float low ps...
[Closed] Fox 36 Float low psi for weight
~I've had these forks since 2008 but of late it seems I need to put only 40psi in them to obtain the right sag (25%) I'm not light at 230lbs either
Up until now I have always run them at about 80psi
Cant get my head round it....
Do they need more or less fluid? (never serviced them myself), last service was on the lowers and seals about 10 months ago
Is this normal???
Posted : 18/06/2013 10:21 am
 LoCo
Air seal on piston maybe leaking allowing oil into the air chamber which'll make the spring 'ramp up' alot more and result in you not needing so much air pressure.
Can you get full travel if you let all the air out?
Posted : 18/06/2013 10:32 am
I will check Loco.
I have noticed that there is some yellow fluid leakage when reducing the air pressure without a shock pump - Is this what you are referring to?
Posted : 18/06/2013 10:37 am
just let all the air out and no I am about 2" from full travel!
Posted : 18/06/2013 10:41 am
 LoCo
Change air seal and see how it works afterwards
Posted : 18/06/2013 10:57 am
Thanks Loco
Its obviously due a service so I will book in, do you service Fox forks now?
Posted : 18/06/2013 11:09 am
Is this air seal change an easy job; anyone done it?
Posted : 18/06/2013 6:26 pm
 LoCo
Yes we service fox forks, the seal change is fairly easy have a look on the fox the site and they'll be details of the service
Posted : 18/06/2013 8:19 pm
