The Fox 32 CTD 'FIT' forks on my '14 Whyte are less than plush. It may be that I'm just too light at 150lb. Anyone got any tuning tips that may help with small bump compliance? I've probably tried everything, but it doesn't hurt to ask the font of all knowledge that is ST.
Have you tried adjusting the trail mode dial on the top of the right hand leg below the ctd lever?
http://www.ridefox.com/help.php?m=bike&id=35
look around 3/4 of the way down the page for adjusting trail mode.
This can be set at soft medium and firm.
I have a friend who was complaining about his being to firm until I pointed out this dial. He thought it was just part of the ctd and not a separate adjustment.
Andy
I don't think mine has this - it will be an OEM fork, won't it?
I'm not sure. I thought they all had it but I have never looked. I have the factory float 32's and my friend has the factory talas 34's which both have the trail adjust dial.
Not all CTD forks have "trail adjust", some are just CTD and you're stuck with the "T" setting of the fork. Only adjustments are rebound (bottom of the fork) or how much air you put in the thing.
EDIT: [url=
]CTD fork here[/url], [url=
]CTD "trail adjust" fork here[/url].
