2 x Exodus light units.
3 x batteries - 1 x quick hardcase qr 2600mah, 2 x 3300mah pouch batteries.
The 3300mah battery packs get both light units to work just fine.
If I try to use the hardcase 2600mah pack with one of the light units it works just fine. However if I try to use it with the other unit the light operates but only on a single mode then switches itself off.
All batteries charged using same charger.
Very confused....any guidance would be appreciated.
Thanks.
Lithium batteries have a lot of overload protection built into them, I guess the drain is outside of the parameters set for the 2600 pack and it's shutting down as a result?
Call them, incredibly helpful
07809 760560
The 2600mah is Li-Ion, the 3300mah ones are Li-Po if that helps.
Yes just give them a call.
