Formila k18 new pad...
[Closed] Formila k18 new pads won't fit, too tight on disc...help?
putting in some new pads and they are too fat, the pistons won't retract back into the brake so i can fit them. Should i just loosen off the little torq key bolt on the calliper (holding it above the lever) and let a tiny bit of fluid out? is so how much? if not what do?
thanks
Posted : 22/09/2011 4:24 pm
Are they superstar pads, by chance?
If so, superstar pads appear to come up a bit thick for Formula brakes - same with my Oros
You just have to ride it out 'till they wear a bit.
Posted : 22/09/2011 4:33 pm
no they aren't and they aren't actually brand new pads either, they are probably about 80% i tried to ride with them in hoping a couple of descents and some hard braking would gradually push the pistons back in as they adjust automatically with wear (no?). however they just rubbed so much and heated up the calliper a lot and just made it worse as heat pushed pistons out even more!
Posted : 22/09/2011 4:50 pm
Put the old pads back in & then introduce a large flat head screwdriver between the pads slowly sliding the tapered head further in.
This should push the pistons back in.
Posted : 22/09/2011 4:57 pm
I had this problem with my k18s (not from new) I needed to bleed them to sort it
Posted : 22/09/2011 5:00 pm
Lubricating the pistons with a drop or seven of brake fluid on a cotton wool bud may help recalcitrant pistons to go back.
Plastic brake levers work well, strong and won't damage the pistons.
Posted : 22/09/2011 5:05 pm
pistons won't go back unless you let a tiny amount of fluid out. Then they will go back easily (should).
Posted : 22/09/2011 5:11 pm
yeah, they move back in, however i push one in the other side just comes back out and vice versa... question is then how do i let a little fluid out?
Posted : 22/09/2011 6:01 pm
In that you're right sorry, you need to let some fluid out. It should not matter which end, but the caliper end will probably be easiest to reach while you're pushing the pistons back.
Posted : 22/09/2011 6:05 pm
