Fork Set-up Advice ...
[Closed] Fork Set-up Advice please
[#2669595]
Just built up a Cotic Soul and put on a set of Rockshock Revs RL 140mm travel(2011)took it out for first ride and the forks felt horrible. Adjusted the air in the chamber and it has improved them a little.
Anyine else have these and could advise me what air pressure I should run them at.
Thanks.
Posted : 17/04/2011 12:57 pm
Have you done a proper sag set up? If not start with the pressure advised by rock shox for your weight and put a cable tie around the stanchion setting it right down on the seal.
Sit on the bike in your normal riding kit and get in to your attack/normal standing riding position, get off carefully making sure you don't compress the forks any more and see how much the cable tie has moved. As a starter look for 25% of the travel so 35mm from the seal to the base of the cable tie.
Posted : 17/04/2011 1:14 pm
