I need to get some rock shox pike 454 serviced anyone recommend a good retailer as the last ones (lbs) didnt do a very good job.
Loco or TFTuned, there are probably others.
I've had some Rockshox Recons serviced by Loco, and he's currently got my Fox Vanillas.
I was really impressed with how the Recons felt when they came back. I'm sure the Fox will be as good.
However depending on what needs doing Pikes are fairly easy to DIY..
Do them yourself, pikes are very easy to service.
Yeah, DIY isn't as tough on Rockshox as you might think.
Only 'specialist' tools you need is some circlip pliers and a 24mm socket.
Thanks for the PDF I'll have a proper read of that when I can print it out. Just had a quick look on what tools are needed and it says frosty cold beverage needed on all services hahaha
