I noticed a tool, rebranded by many, that facilitates a 32mm seal in one end and allegedly, a 34, 35 or 36mm on the other.
Anyone tried one? How well does it accommodate the three sizes? Is it 34mm and gets more loose fitting as you go up the sizes? Or is it 35mm and a bit loose one way and a bit tight the other?
Or given the price of forks and seals, should I just spend £10-15 on one of each size required?
Posted : 31/01/2024 3:46 pm
I have one of those tools. I've only used it on 32 and 34mm seals and it worked well on both.
Posted : 31/01/2024 6:14 pm
Thanks @scotroutes
How is the fit with the 34mm seal? Is it an easy fit,or is the seal quite snug on there?
Posted : 31/01/2024 6:25 pm
I don't recall having any issues
Posted : 31/01/2024 6:31 pm
