Fork grease
[Closed] Fork grease
[#1326838]
Got a a families worth of forks to service & wondering what proprietry grease I can get in a decent sized tub, rather than spending oodles on those miniature pots & tubes that cycle shops sell. Thanks
Posted : 15/02/2010 12:01 pm
Silkolene RG2 Grease from your local motorcycle shop, not paricularly mega cheap but good stuff
Posted : 15/02/2010 12:31 pm
Thanks, is that Silkolene RG2 defo okay for fork seals?
Posted : 15/02/2010 1:15 pm
 nuke
I use Rock N Roll Super Slick grease...
http://www.thebikechain.co.uk/store/product/18307/Rock-%27n%27-Roll-Super-Slick-4oz/
Posted : 15/02/2010 1:31 pm
 Del
or stendec fork grease...
Posted : 15/02/2010 5:02 pm
apart from seals, I didn't think that many forks actually used grease these days.
Posted : 15/02/2010 5:43 pm
Scienceofficer - I think you'll find that because I tend to buy things cheap just after they go out of fashion but before they become retro, then most of my forks will need plenty of grease.. 😳
Posted : 15/02/2010 8:28 pm
Manitou do tubes of M-prep fork grease, my local Go-Outdoors usually stock it.
Posted : 15/02/2010 8:30 pm
Any old grease will do then IMO Big tub of castrol LM.
If there is no damping oil then all the seals do is keep the dirt out
Posted : 15/02/2010 8:31 pm
I love the silkolene RG2 but I wouldn't put it near the insides of any forks. I've got a tube of M-Prep, some Pace stuff and some old Judy butter. All in reasonable sized packets and all lasting well. If anything, the Judy butter is lasting too well as the name might suggest.
Posted : 15/02/2010 8:37 pm
LOL dickyboy!
Posted : 15/02/2010 10:56 pm
No LM grease will cause seal swell (assuming by LM your referring to Lithium grease)
Posted : 16/02/2010 12:37 am
If the forks don't have damping oil in them but are just greased springs then it will only be dust seals so will it matter?
Posted : 16/02/2010 1:00 am
There's often a lot of plastic parts in forks like that. Some plastics and some greases don't mix well. I think that's the main reason the suspension specific stuff came about.
Posted : 16/02/2010 8:56 am
Ah - point taken onzadog
Posted : 16/02/2010 9:00 am
What about Moly Grease or paste, reason I suggest this is because Moly is what is used in spring powered air rifles, which is a plastic (or leather) seal that slides down a steel tube, same principle but opposite?
Jay
Posted : 16/02/2010 11:02 am
All as clear as daylight then? Doesn't really help knowing that at least two of the pairs of forks I am servicing are oil damped in one leg only.... looks like I might have to buy the tiny expensive pots afterall. The Magura Ronins service require equivalent to one pot of judy butter - ie 15ml per leg, so you can see why I would have liked to have found a cheaper option.
Posted : 16/02/2010 5:43 pm
Looks like Stendec fork grease will be the best bet £9 for 150ml should do a few forks (as opposed to £5 - £12 for 29ml of Judy Butter!) cheers Del
Posted : 16/02/2010 6:27 pm
Get some Rock n Roll Super Slick grease, it's designed for forks.
Posted : 16/02/2010 6:31 pm
