Have any of you replaced the bushings on your forks? Rock shox pike 426 needing done here.
Was reading the SRAM tech manual online and it doesnt seem that difficult a job at all, but the specialist tools aren't readily available on the net as far as I can see.
Anyone know a good source for the bushing pullers and the punch bit to put the new ones in?
I would rather have a go at it myself, even if buying all the bits totals as much as sending the forks off to TFT. There's a couple of pairs of Rockshox in the family fleet so the tools would definitely be getting a good bit of use over time
Nobody?
I hope you really know what you're doing.....
I think there's a reason the removal tools aren't readily available.
I would just send them to TFTuned if i were you.
Look at Enduroforkseals.com,they've got a pictorial of replacing a dual air Pike's bushings,it's probs very similar
Ian
