on my 2006 ford focus hatchback
while I steer to full lock, at low speeds, I hear a creaking sound from the left front wheel area. This is only while actually moving the steering wheel - while driving slowly at full lock no further noise appears.
any ideas what it might be - i got it second hand a few months ago and think its still under warranty, so will get them to take a look at it - but any extra info (or even pointers to a specific motor forum) would be appreciated. I wouldnt think CV joints would go at 2 years old, but could be wrong !
(and i know this should be in the Off Topic forum - teething problems 😉
Just had that on my focus - drop link on the suspension - common issue
cheers, how much time / money did it cost to sort?
was part of a big service - part is £25 plus fitting iirc
thank you.
Drop links are easy to check, can just about get away without needing to jack the car up too.
If you do want to check them, they shouldn't move at all - should be stiff.
Silverside,check out these sites:www.ffoc.co.uk & www.focusowners.com.
You'll need to register (like on here),to post a question,but i'm sure someone on there will know the answer.
To find out if the droplinks are knarked, you need to jack the front end of the car up (both wheels) to take the weight off the ARB, If theres play in them they need replacing.
Generally a droplink will knock while driving over imperfections in the roads surface, If it doesnt do this I suspect something just needs a lube up ARB bushes tend to be my first point of call
yeah makes sense , i thought i heard a bang on a country road...
