Foix FIT damper ser...
[Closed] Foix FIT damper service - As hard as it looks?
Fox F32 RL, on a mates 2010 Giant Anthem
He's been advised to spend the thick end of £300 by an LBS for replacing virtually his whole fork because the FIT damper has, and I quote the shop here:
"Replace RL cartridge as internal seals have failed, replace with replacement FIT RLC cartridge seals and new oil"
They haven't taken this fork apart. I don't think they've done any more than bounce it up and down to be honest, the same as I have. It's got a rather harsh top out clunk, but that's all
So. I've found sone instructions (From Fox) and they go into great detail about stripping the cartridge into it's smallest component part, to replace a couple of seals. It looks like overkill, but I've never had a Fox apart before.
So, can you get the FIT internal seals?
Might just a quick oil change be worth trying?
Should I give it a shot? (I can do RS forks with my eyes shut)
Any other advice? 🙂
Posted : 05/02/2013 9:46 am
Oh, numpty question:
Is the FIT cartridge the AIR or the DAMPING side? I've just realised I don't know! (I think it's damping)
Posted : 05/02/2013 9:49 am
The FIT cartridge is the compression dampening and rebound side of things. The air spring is in the other fork leg.
But that's about as far as I can help you, as both my forks are open bath, partly because I'm too cheap to buy a FIT cartridge fork, and partly because I've heard the FIT cartridges are beyond most amateur bike fettlers capacity to service.
I do Ok servicing my open bath forks, but I'll let someone with more expertise tell you how difficult it is to do a FIT cartridge...
Posted : 05/02/2013 9:57 am
Mmmmmmmmm not sure. I've read the instructions. It's a long winded faff, for sure, but it's only unscrewing things and putting them back together at the end of the day. 🙂
Posted : 05/02/2013 10:01 am
To be honest, I'm probably not going to do it. If the forks were mine, I'd be in there already, but they aren't....
He did call TFTuned and they rubbed their chins when they heard what the shop had said!
But I am toying with the idea!!
Posted : 05/02/2013 10:04 am
 LoCo
Not being in possession of all the facts or having the fork in front of me I can't say for sure (although when has that stopped anyone commenting 😉 )
The seals are replacable on the FIT cart, and we offer services on just the FIT dampers.
The issue is if parts have been damaged inside the cart. and I'm not sure whether you'd be able to get the parts Peter.
Posted : 05/02/2013 10:34 am
Why would you throw a way a damping cartridge and put a brand new one in, when all you need to do is replace the seals in the old one?
Christ even sending the whole fork away (not just the damper assembly) would cost more than £100 or so to give it a good seeing to.
I think you need shaft clamps to get into the RL damper, but not sure about sourcing new seals? Simon @ Loco Tuning will be able to advice / do the work im sure.
Oh and the LBS are talking out of their arses, without taking it apart how could they possibly know?
Posted : 05/02/2013 10:36 am
If it's an F-Series 32RL then it has open bath damping- not FIT damping. You certainly could replace with a FIT damper but tbh you'd be better off buying a new fork in the sales or sending it to someone who knows what they're doing like MOJO or Loco. (If you don't fancy servicing yourself I mean)
In terms of home servicing its very easy until you start stripping the actual damper down, which is much more involved. This is what your shop is saying they don't want to do, they're going to order a new damper assembly and fit it (Changing the bath oil at the same time). Mojo/Loco can strip the damper and service as required.
Posted : 05/02/2013 10:50 am
Not being in possession of all the facts or having the fork in front of me I can't say for sure (although when has that stopped anyone commenting )
Yes. This is the thing..... Can YOU get the parts? I said he's better off sending the fork away to you whilst I do the ret of the bike.
This is why I like Rockshox..... 😉
Because you are a BIKE SHOP and that is faster and makes more profit. Which is what I'd expect, nothing wrong or new there!
That's exactly what it is. do FIT forks say FIT on them?
Posted : 05/02/2013 10:59 am
 LoCo
Rebound (red knob 😉 ) is on the bottom of the leg in FIT carts.
We offer just a FIT damper service, so customers can service the chassis, wiper seals etc and send the damper into us.
Posted : 05/02/2013 11:04 am
Rebound is on the top, with lockout in the middle.....
Posted : 05/02/2013 11:05 am
double post
Not sure it's any help, but the Fox F125RL forks from my 2012 Giant Trance X2 are definitely open bath. I considered upgrading to FIT, but the quote from Mojo was around £200 (on top of the £100 for the service).
EDIT: Turns out I was right, it wasn't any use 🙂 as LoCo chipped in with a much more useful answer as I was typing.
Posted : 05/02/2013 11:06 am
 LoCo
OB cart then, so they're saying the damper is screwed and to replace with a FIT damper (which seems a touch pricey to me).
Refer back to my comment about not being in full possession of facts/fork infront of me etc 😉
Posted : 05/02/2013 11:07 am
SO what we're saying here is that the (Large, posh) bike shop is talking out of their arse?
Posted : 05/02/2013 11:11 am
[url= http://farm9.staticflickr.com/8466/8447554212_ff312c9c16_z.jp g" target="_blank">http://farm9.staticflickr.com/8466/8447554212_ff312c9c16_z.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/peter_atkin/8447554212/ ]Untitled[/url] by [url= http://www.flickr.com/people/peter_atkin/ ]PeterPoddy[/url], on Flickr
[url= http://farm9.staticflickr.com/8074/8447554594_1d60e2f581_z.jp g" target="_blank">http://farm9.staticflickr.com/8074/8447554594_1d60e2f581_z.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/peter_atkin/8447554594/ ]Untitled[/url] by [url= http://www.flickr.com/people/peter_atkin/ ]PeterPoddy[/url], on Flickr
Posted : 05/02/2013 11:12 am
I have an F120 with a FIT damper..........
Like has been mentioned above- how can they possibly know whats wrong with it without taking it apart. Although a harsh top out does seem quite likely to be the oil draining out of the damper - but I would want to see it before making the call.
Iv rebuilt a FIT damper from a 36 fork without any of the special tools I was told I needed. It was quite easy - didnt change any seals though- mine just had air trapped under the diaphram.
Posted : 05/02/2013 11:16 am
Thats an OB damper as loco says.
Ones in good working order sell for ~£200-250 s/h tops.
Posted : 05/02/2013 11:17 am
 LoCo
No Peter, it's an OB damper and I think they are suggesting an upgrade to the FIT damper system,.
ndthornton, there are two types of FIT damper the 'older' one fitted to the 36 is easier to do, best to replace the bladder if it's 'burped' as they tend to distort and do it again fairly quickly 😀
Posted : 05/02/2013 11:19 am
Lovely! 🙂
As easy to service as RS then?
Are there any technical manuals about like SRAM do?
What weight damping oil do I need?
Posted : 05/02/2013 11:28 am
This shows the oil volume and type:
http://service.foxracingshox.com/consumers/Content/Service/oil_volumes.htm
Tech info here:
http://service.foxracingshox.com/consumers/index.htm
I'd do a simple oil bath change and clean the wiper seals, lube the foam rings and put it back together. DO NOT forget to check the air chamber as it's likely most of the lower leg lube oil has migrated up there. There is info how to do this in the above link, but you might have to dig around for it.
Chances are that will sort the fork out unless its been run without oil for a long time. If it doesn't work you've got the choice of rebuilding the damper youself or sending it off to loco/mojo.
Posted : 05/02/2013 11:34 am
just out of interest does this void any warranties?
Posted : 05/02/2013 11:51 am
They'd have no way of knowing you'd had it apart if done properly. I believe Fox encourage users to do wiper seal services themselves anyway, but obviously I don't speak for the company so couldn't say 100%
Posted : 05/02/2013 12:29 pm
Cheers Roadwarrior, good info. I'm going to give it a shot in the next day or so 🙂
Posted : 05/02/2013 12:57 pm
As we've established they're actually the open bath model, then yes its a pretty simple procedure. Just get yourself a 32mm dust wiper seal kit, a bottle of Fox 10wt green oil, and have the following tools handy:- 22mm socket, 10mm socket, seal pick, plastic faced hammer.
Then, follow the instructions [url= http://service.foxracingshox.com/consumers/Content/Service/Forks/FLOAT/FLOAT_RL.htm ]here[/url]
Posted : 05/02/2013 1:14 pm
22mm socket? 26mm isn't it? 🙂
Posted : 05/02/2013 1:25 pm
 LoCo
26mm, 6 sided and machined ideally, if the damper is knackered though they are rebuildable with kits, various things can cause klunks and clips in those.
Posted : 05/02/2013 1:27 pm
Got 24mm (Rockshox) and 27mm (GPZ500 rear spindle IIRC!)
arse.
Posted : 05/02/2013 1:38 pm
Yep - 26mm, sorry!
Posted : 05/02/2013 2:08 pm
Other things to have on hand; fox float fluid for the air chamber (3 or 5cc required), crush washers for the base and syringes to measure out the float and damper fluid. (Last time I got 10 from ebay for about £3).
You might not need the washers, but if the fork leaks when you put it back together it's annoying having to wait for a delivery before you can ride!
Posted : 05/02/2013 3:48 pm
I'm currently halfway through a service of my Fox forks, while I await some bits. I was looking for online guidance yesterday and found this, which is basically the answer to your question:
http://www.hackracer.com/2012/04/tech-part-3-of-4-how-to-replace-seals.html
http://www.hackracer.com/2012/04/tech-part-4-of-4-how-to-bleed-fox-fit.html
Incredibly detailed, illustrated and comprehensive. Useful! Part 4 above is particularly relevant to your query.
Posted : 05/02/2013 4:00 pm
roadwarrior, can you elaborate on your point about checking the air chamber? Mine (Float 100s) are currently disassembled until I get home tonight. All the oil has definitely drained out of the damper side. The air side oil has drained out of the bottom but there is still visible oil under the top cap on that side. I was unsure as to whether it was essential to drain and replace this as well as I thought it might be sealed enough that it was ok. I haven't found a definitive answer online so if you can advise I'd be most grateful!
Posted : 05/02/2013 4:07 pm
flatboy; see here; http://service.foxracingshox.com/consumers/Content/Service/QuickTech/AllAirSpringQuickService.htm
Ignore everything before step7. You simply remove the air side top cap (DONT FORGET TO RELEASE THE AIR VIA THE VALVE FIRST!) empty out the old fluid and clean out everything and replace with 5cc of float fluid. The oil volumes chart I linked above confirms the quantity.
The oil in the air chamber will effect the linearity of the fork, you need some for lubrication but too much will cause the fork to ramp up sharply due to the reduced volume of air in the chamber.
You'll likely empty out more than 5cc because it tends to migrate from the lower leg.
One other thing- that link above is helpful but I would not wash any of the fork internals out with soap and water. If you want to clean anything use IPA or some solvent that will evaporate completely. Last thing you want is water and soap in your damper fluid.
Posted : 05/02/2013 4:32 pm
nice one, cheers sir.
doing this job has made me think more than ever before that i need a torque wrench. not having one, i assume i'm going to die after i tighten everything up again... 😯
Posted : 05/02/2013 4:38 pm
removed. I've already said that.
Posted : 05/02/2013 4:43 pm
 LoCo
The oil migration issue, was mainly with the newer spring assemblies, that had the foam ring fitted below the air seal on the piston, these are replaced with scraper/lip seals.
Another quick question, while the experts are clearly in the house - I noticed that at the very bottom of both lower legs there are what seem to be black rubber washers (one per side). At least one is loose and I was a little worried it had come detached from somewhere, but seems to sit in what looks like the correct spot at the bottom of the leg with a bit of wiggling. I take it this is all ok?
Posted : 05/02/2013 4:48 pm
That's the crush washer. They're consumable. Keep using them until they weep oil, then replace. Mojo sell them, as do others I assume
Torque wrench? Nah, just nip everything up and don't go crazy and strip any threads.
Posted : 05/02/2013 4:51 pm
Not the crush washers - on the inside, similar to the foam rings in appearance (but black), and smaller so they sit right at the bottom of the lower legs. I can put a pic later. I'm fairly sure they're ok where they are (as I can't work out where else they could have come from! but am not sure.
Posted : 05/02/2013 4:55 pm
 LoCo
Bump stops, clean, little grease and locate in lowers so holds them in place 😉
Posted : 05/02/2013 5:11 pm
Good stuff, I really appreciate the input chaps - I won't forget you Loco when I **** it all up later on. 🙂
Posted : 05/02/2013 5:14 pm
 LoCo
Remember tighten everything up till it shears and then back it off a 1/4 turn, that's just right 😯 😉
Posted : 05/02/2013 5:15 pm
Loco makes a good point here, and its worth reiterating in case anyone missed it.
There was a batch of Fox forks from 2010-2012 which had a design fault. They added a foam ring to the air spring piston to keep the seal lubed and running smoothly. Here's a pic of the air spring showing the foam ring (yellow) and rubber seal (black)...
However, over time it had an undesireable side-effect of promoting the transfer of oil from the lower fork leg to above the air spring. This had two results - 1. Eventually leaving your lowers in that leg dry, with no lube for the bushings, and 2. Oil being uncompressable, the performance of the air spring was degraded and travel reduced. However, it happened so gradually that it was hard to notice until one day you suddenly realise you are only getting an inch of travel out of a 4 or 5 inch fork.
Fox never really admitted to the problem (I'm guessing American company + lawyers = liability issue), but did quietly tell their service agents to replace the foam ring with a rubber scraper seal anytime one of these forks came in for a service. They were also happy to send out the scraper seal FOC to any DIY maintenance owners who requested it. However, there's undoubtedly a large number of forks out there still with the problem if they've never been professionally serviced, or the owner never noticed the issue. For example, take a look at this thread [url= http://singletrackworld.com/forum/topic/fox-float-32s-lowers-oil-in-the-air-chamber ]here[/url]
So, if you're going to pull one of these forks apart yourself, take careful note of how much oil is above and below the air spring (should only be 5cc of blue float fluid above, and the Fox oil volumes table will tell you how much oil should be in the lowers). Then have a look at the air spring itself, and if its got one of those foam rings on it (not to be confused with the foam rings under the dust wiper seals!) then contact Mojo and get them to send you a rubber scraper seal to replace it with under warranty.
Posted : 06/02/2013 5:19 am
ok, more assistance needed! all done, cleaned, fox fluid added, oil added in what appears to be correct quantities from Fox, most of the assembly seems to have gone smoothly.
Problem - putting the controls back on the top assemble on the damper side, it appears that the rebound, lockout and compression controls have all seized together, i.e. once the controls are all back in place they don't do that they are supposed to. the fork compresses seemingly fine, but then takes literally 20 seconds to rebound. not ideal!
any ideas on trouble-shooting / remedial steps?
Posted : 07/02/2013 1:23 pm
 LoCo
so even with rebound on full fast the forks are very slow to return?, if all dials are moving the lockout knob and ball bearings are misaligned and need to be reset, can be a bit fiddly.
Posted : 07/02/2013 1:25 pm
well i had all three knobs off to get that top 26mm nut undone. even with none of the knobs in place the whole assembly moves as one. i went through the fiddly process of alligning the bearing / needle / allen key bolts etc, but the compression clicker doesn't move separately to the rest of it. 😡
Posted : 07/02/2013 1:34 pm
 LoCo
You'll have to stripp the topend of the damper to clean regrease by the sounds of it.
Posted : 07/02/2013 1:45 pm
ok, i'll have another look when i'm home. sounds like all that lovely oil might be coming back out of the fork then! cheers once again.
Posted : 07/02/2013 1:48 pm
one last question (i promise!) - is there any way of trying to get it all freed up from the top, i.e. without doing a full disassembly again?
Posted : 07/02/2013 2:39 pm
in fact, thinking about it i'm being stupid - i can just undo the 26mm nut on the topcap, plus the bottom nut, drain out the oil and lift the damper out, right?
Posted : 07/02/2013 2:55 pm
 LoCo
The lock out hex, will spin out and is cleanble, but you'll have to remove the detent bearings and and spring from lower down, have a loock at the fox drawings and instructions here:
http://service.foxracingshox.com/consumers/index.htm <
Posted : 07/02/2013 3:04 pm
gotcha, i think from having had it apart already that should all be fine. the only thing i'm worried about is whether the seizing could be do with something internal, i.e. misaligning or damaging some part of the damper assembly mechanism?
Posted : 07/02/2013 3:07 pm
Info on re-assembling the top cap parts at the bottom of this page in case you haven't seen it yet;
http://service.foxracingshox.com/consumers/Content/Service/QuickTech/32Gen3OBRL_ServiceProc.htm
Let us know how you get on!
Posted : 08/02/2013 10:47 am
thanks - i did follow the guidance on reassembly and to be honest thought it had gone smoothly. everything at least appeared to have gone back in the right place etc. and fitted neatly together. the reason i realised all was not right is that the red compression adjustment (i think) on top is not indexed at all. in fact it doesn't spin independently of the lockout lever. and there is no damping. well in fact there is - far too much with no adjustment at all!
planning to have that side apart again over the weekend to see if there is anything that appears to need freeing up other than the top cap assembly.
Posted : 08/02/2013 11:39 am
 LoCo
It maybe that the rebound rod has lost, the tangs off the lower end and may spin and not adjust anything, this is quite easily done if the rod seizes as the tangs are pretty small so doen't take much force to do, if you get more issues we can sort it all for you 😀
Posted : 08/02/2013 11:52 am
It must be worth pointing out that if there is too much oil in the damper side, it will lock out.
Are you sure the amount is right? Was the damper completely empty before the new oil went in?
<edit> re-read above; this doesn't seem to be the issue.
Posted : 08/02/2013 12:00 pm
that did occur to me, scott - i cycled the damper mechanism up and down a load of times, and it did appear to be empty. because of limited time to do the job in the evenings it was up on the stand draining for a good couple of days as well, so would have thought it was empty!
i got the volumes from here:
http://service.foxracingshox.com/consumers/Content/Service/oil_volumes.htm <(line 8 ) so assume i didn't make some stupid mistake on that, though it's quite possible!
the fork compresses fine, just rebounds ridiculously slowly and, as above, no adjustment at top cap assembly.
Posted : 08/02/2013 12:05 pm
Right, a weekend update. I have got the damper assembly out of the leg but unforunately the Fox info on damper servicing doesn't seem to include the actual fork I have. I got the topcap apart from the damper shaft, took that all to bits, cleaned and reassembled. I now know the issue is not to do with this area, but at least am now an expert on how it all works!
The problem is that the rebound adjustment shaft is stuck in place - I don't think that the bottom of it is broken as info I got elsewhere suggests that that would mean the shaft / dial would spin freely and at the moment it doesn't turn at all.
So, I need to get the damper assembly apart to work out why the rebound shaft isn't turning. Any suggestions on what could be the issue or what to look for would be very welcome. I need to get a spanner slim enough to fit the nut, as my homebase adjustable doesn't quite do it!
Progress, it seems, has been made. However, not there yet!
Posted : 09/02/2013 2:09 pm
Update from me too 🙂
I had my mates forks apart, and they are NOT FIT forks. So the bike shop was bullshitting him and trying to get him to spend the thick end of £300 on something he didn't need or want. It's the Giant Concept store in Guildford if anyone wants to know.
So, I took them apart, left the rebound cartridge well alone, cleaned them out, refilled with new oil both sides as per the info on this thread, and put them back together. No more than that. Easy peasy. (FYI they had the wiper seal but no foam ring on the air piston, unlike the pic above)
The result is that the knocking noise has gone and they feel buttery smooth again for about £3 worth of oil.
Said mate is very pleased indeed. 🙂
Thanks to everyone on this thread for the info and the links. That's saved someone a big old wedge of cash! 😀
Posted : 09/02/2013 3:33 pm
I did mine today as well under the tutelage of Andy at purple bike shed (I wanted to find out how to do the foam and wiper seal every 30 hour service, but once you have it apart it's pretty easy to do the oil change and new wiper seals anyway). Will be in touch with mojo for the foam ring on the piston replacement for next time. Dead easy!
Posted : 09/02/2013 5:25 pm
ok - problem solved and fork working perfectly. 🙂
had the damper assembly sitting there cleaned up but still not working. had a think about it last night. ended up taking another look, and considering that the rebound shaft was stuck, rather than spinning freely. having seen how the rest of the adjustments worked I concluded I'd give it a go to free it up. Got a spanner on it, rather than the rebound dial and gave it a bit of effort anti-clockwise. As if by magic, it freed and unscrewed, with the indexing clicking away nicely.
I think it must have bound with the lockout nut when i put it all back together and screwed in and got stuck when i first re-assembled it. Now all back together and the whole fork is working beautifully. Happy days!
Posted : 10/02/2013 8:23 pm
That can also be caused by not holding the rebound adjuster when you tighten or loosen it's bolt, had to take one to Mojo (still under warranty, so they recommended I didn't touch it)to be fixed after the owner hadn't done anything whatsoever to it, and definitely hadn't tightened it with a long arm allen key 😉
Posted : 11/02/2013 8:24 am
that could feasibly have been it (not the long arm allen key part) - might well have done that on first reassembly, to be honest, can't be sure.
still, pleased to have got it working again and now i know a lot more about how it works then i did a week ago!
Posted : 11/02/2013 10:21 am
[i] So the bike shop was bullshitting him and trying to get him to spend the thick end of £300 on something he didn't need or want. It's the Giant Concept store in Guildford if anyone wants to know.[/i]
Pretty shocking that (oh dear, no pun intended!)
S'why I'd always send my forks to TFTuned if there was something wrong I couldn't do myself. Or maybe now PPTuned 😉
Posted : 11/02/2013 10:42 am
 LoCo
This is quite common, the rebound barrel adjuster gets jammed at the end of adjustment and you can sometimes free it off turning in opposite direction, however sometimes it'll just snap the rod tangs, it's best to fully strip the cart and release the barrel, although you do really need the correct shaft clamps to reduce the chance of damaging the cart as the body is pretty thin tube.
Glad you got the cart. fixed 😀
Posted : 11/02/2013 11:13 am
Cheers sir, and thanks again (to you and others who chipped in) for the pointers. As I said, I'll bear you in mind next time I need something doing. 🙂
Posted : 11/02/2013 1:04 pm
