Flying hand luggage...
[Closed] Flying hand luggage. Reverb Dropper post???
So I'm flying back to Cyprus on Wednesday.
I flew to the uk with hand luggage only.(cabin not in the hold)
I've picked up a reverb dropper post and want to take it home in my hand luggage.
Will I get through the scanner? Is it prohibited?
I'm flying with easy jet. Don't think that matters as the scanner is at the beginning for every flight.
Any input would be great. Don't think I can call as trying to explain what it is over the phone won't be easy.
Posted : 20/11/2014 7:29 pm
'STW Style Uninformed opionion': Probably not, as it contains liquid!
Posted : 20/11/2014 7:46 pm
Pressurised cylinder with liquid in it?
Hmm.
Posted : 20/11/2014 7:52 pm
Scanner won't be able to see the liquid or compressed air inside the metal tube ๐Ÿ˜‰ fingers crossed the staff don't know what it is ๐Ÿ™‚
Posted : 20/11/2014 7:57 pm
Email Easy Jet and ask the question, you could release the pressure, can you remove the valve core, I don't know, then you're just left with titchy bit of fluid. Expensive thing to have taken off you.
Posted : 20/11/2014 8:04 pm
It was the taking off me I was worried about.
Perhaps an email with a picture.
Posted : 20/11/2014 8:20 pm
Having had a scan through the gov.uk website on what's allowed in cabin and hold baggage, I'd say 'no'.
It wasn't the hydraulic fluid or pressurised air chamber bit, but the fact that even tennis rackets and walking poles are not allowed in the cabin, presumably as they can be used as weapons/clubs. The same logic could extend to even a 'normal' seat post, so I'd not risk it with a Reverb.
Posted : 20/11/2014 9:25 pm
Good news
Dear sirs
I hope you can help please.
I am returning to cyprus with only hand luggage, I have purchased an item for my bicycle and wish to know if I can take it in my hand luggage and pass through security?
This is the item.
It's a seat post that goes up and down via a cable and lever.
http://www.chainreactioncycles.com/rockshox-reverb-seatpost/rp-prod84856?utm_source=Google&utm_medium=Shopping&utm_name=UnitedKingdom&gs=1&gclid=CLOSt5eRi8ICFY_MtAod-lkAyw&gclsrc=aw.ds
https://m.youtube.com/watch?v=CK6HhuTfagM
It has a small amount of hydraulic oil in the attached cable. And is around 400mm long.
I look forward to your reply.
THE REPLY
Good Morning Chris.
Thank you for contacting Bristol Airport.
I have spoken to security and can confirm you may take the item you described through security in hand luggage.
Kind Regards
Sam James
Enquiries
Customer Services
Bristol Airport
Bristol, BS48 3D
Posted : 21/11/2014 2:22 pm
 Sui
result, take that letter with you!!
What has happened in the past with stuff like this, is it's boxed up and sent to the hold, wherupon you get a ticket and collect it again at the other side..
Posted : 21/11/2014 2:29 pm
Sailed straight through not even a glance at me.
Yaaaa
Posted : 27/11/2014 11:25 am
Good on you, especially for checking in advance.
It's probably a tricky one to handle, as where do the draw the line? Seatpost could be used as a weapon, as could even a chainring, or chain for that matter.
Posted : 27/11/2014 11:43 am
