I understand? That jump/dirt riding needs pedals that don't spin? (True?)
But Im trail riding- one spins fairly stiffly, the other as stiff as they both were at new. Fruit at superstar said 'they will break in'. Really? True? I only realised how bad it is when I switched to clip in pedals last night. Like night and day (but I hated the foot position so switching back)
Junk the Superstars but buy what flats?
Strip and grease? My Nukeproofs (same as Superstars) are fine - spin freely and still do after 18 months of abuse.
with a rock?
Will strip and grease first
I have 2 pairs of Superstars nano's both spin fine.
Either cone is too tight on the axle or a clean and grease required.
Thats a bit if a novice question to ask though hora. I should have thought it was pretty obvious they should spin freely.
Strip and grease anyway. Some nice thick marine grease will help keep the crap out too.
But don't get too carried away with the notion that they should spin freely in a no-load situation. That's not representative of use at all.
You want them to turn freely with a fat middle-aged mountainbiker stomping on them. That's a whole different measurement.
Good example is the fabulously expensive Syntace pedals : [url= http://www.bromleybike.co.uk/shop/components-spares/components/pedals/mtb-flat-pedals/syntace-numbernine-titan-pedals-1032725.html ]syntace-numbernine-titan-pedals[/url] which won't spin in your hand at all.
4months ago I was on the same DX spd's for 7yrs
They should spin freely enough that you wouldn't feel any drag/resistance whilst pedalling. If they are stiff enough to feel whilst pedalling then somethings not right.
Are they over tightened on the axle? I'd try backing the axle nut off a few mm at a time (check for side to side play though).
Superstar innit.
Bearings will have failed but you have voided warrenty by opening the packet.
I've got a rock you can borrow to hit them with
Burgtec
If the bearings have a good amount of grease in them the pedals won't spin fast... that's fine though. I assume you mean they don't do loads of revolutions when you spin them, rather they just do 1/2 - 1 turn or something like that? That's totally normal and a good thing.
Just get riding!
Don't hit them with a rock - a shiny pebble is the tool of choice for freeing up pedals.
But it needs to be damp!Don't hit them with a rock - a shiny pebble is the tool of choice for freeing up pedals.
They already look like they've been hit by many rocks in only a few months ๐
www.flickr.com/photos/30625376@N06/11192794364/lightbox/
They dont spin one bit full stop.
