Flat Pedals- what s...
[Closed] Flat Pedals- what sucks
I'm using Kona wah-wahs, cant fault them so far....only £30 too.
Posted : 04/08/2011 9:07 am
robsoctane, Ive seen on some web page someone drilled so small hole in pedal body above the axle, effectively making a grease port, just pumped grease in through it til dirty stuff came out the ends.
My f(l)atboys are too new to take a power tool to but might give this a try when they are getting tired.
Posted : 04/08/2011 9:52 am
Can I just point out the Crank bros had two 5050's, the x and the xx. The x was awful, raised hump over the axle meant you had a conves pedal, useless. The XX on the other hand used needle bearings on the inside and a sealed cartridge on the outside, I just replaced the bearings in one of mine after 4 years as it had developed a creak due to play. I did keep them greased at regular opportunities though. Grip was comparable to other flat pedals I've used with 5:10's.
Posted : 04/08/2011 10:00 am
I have had wellgo V8 copies, some "Grey" CNC jobbies, two pairs of MG1s and a pair of Nanos.
I recommend the nanos highest. Do the job, the low-profile nature of them is great, decent weight and they are resilient.
I do NOT recommend MG1s. I have one wellgo badged pair and one Onza badged pair (Onza Hognesium). Both suffer from chronic pin loss - what happens is when they get bashed on rocks (common enough occurrence on Peak District rock gardens) the pin gets smashed out of the pedal. However, as the pin is made of steel that is much much harder than the magnesium that the pedal is cast from, the pin shears out taking any semblance of thread and usually a decent chunk of metal along with it. You can replace them by cleaning out the hole and putting a new pin in and setting the base of the pin (and filling the remainder of the hole) with JB Weld, ending up with a 1-2mm high dome of JB weld around the pin above the metal of the pedal frame. Anyway, the point is that MG1s are not as resilient as nanos. Lots of people will say that they've used their MG1s for ages with no problem and that's fine - my own pairs have lost about 10 pins between them due to this problem.
I don't find the two particularly different in terms of grip (using 5-10s), but I imagine that it will depend also on how big your feet are. Nanos have a bigger platform than MG1s.
Posted : 04/08/2011 12:35 pm
Aye, magnesium body pedals will always be weaker for pedal strikes, that's just the tradeoff of the weight. Think I've been lucky not to lose any.
If you want proper weak, try the magnesium nanos, there's not much thread in the pedal just to make it even more delicate than the MGs.
(if you end up with a dome of jbweld, you're using too much, btw)
Posted : 04/08/2011 1:10 pm
The dome was deliberate, to add a bit more anchoring strength. It doesn't detract from the grip but nice to know it's not just me resorting to that.
Posted : 04/08/2011 1:13 pm
Another here for wellgo mg1 pedals.
I love riding with flat pedals, have no intention whatsoever of going clipless, i have tried but just didnt like it and also contemplated trying again but like my flats too much.
Shin slaps hurt like hell and its not so pleasant when your foot slips off and they rub up the back of your leg but this happens so rarely it isnt really worth mentioning. I cant actually remember the last shinslap i got (jinxed it now probably).
I can ride as fast as the majority of my riding buddies, with exception of the ones who are just exceptionally fast full stop.
I dont feel they hold me back at all, i get good grip from just shitty cheap trainers and my feet rarely come off the pedal.
Posted : 04/08/2011 2:38 pm
Kona Wah Wahs are not the same as Superstar pedals!!!
There are 10 smaller M3 thru pins on the Konas and 8 M4 on the Superstar (M4 size is what most other pedals thru pins are too).
Bought a pair of Wah Wahs myself from e bay for £30 as they were cheaper than the Superstar "lookalikes" however the hexheads on nearly all the pins rounded when I tried to remove them.......Perhaps I should have gone for the more expensive Superstar copies after all!
Posted : 04/08/2011 11:02 pm
Page 2 / 2
