looing for a wide flat bar any idea's ?
cheers
dc
I'll open bidding at [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=45573 ]760mm[/url]
not any good in the woods then at that width!!
I could make you a stem that would take a 12 foot scaffold tube if that would help.
I'll even make some new clamps for your brakes & shifters if you like.....
what about grips though?
I'll open bidding at 760mm
I see your 760mm and raise you to [url= http://www.blackspire.com/qs/product/83/5950/445827/0/0 ]800mm[/url].
Ok, seeing as it's you I'll sort out the grips too, hope you like them thick... ๐ฏ
I'll see you and raise you 40mm with Kore Torsion 800mm flat bar [url= http://www.bikeradar.com/gear/category/components/handlebars/mountain/product/torsion-flat-bar-09-35189 ]here[/url]
I see your 800mm and raise you to 820mm
It's not flat. Fail ๐
Not flat, but still ridiculous. That's almost 20cm wider than the bars on my HT!
Yes I know ,but how wide? you must need arms like a gibbon to use those!!
My Sunline's are 762mm and have no problems in the woods. You'd be surprised at how wide the gaps between the trees are.
